Few questions for new build. And sponsors
Old Apr 13, 2011 | 08:12 PM
f3rr3t's Avatar
Default Few questions for new build. And sponsors
First off this is going to be a long project not a 6 month deal.
I would like to use a dart block as i dont want to go bigger in the future (more boost and the block be a concern.
Now i can either get the B18 block with a deck height of 211.5mm or the b20+ block with a deck height of 226mm Was told they are the same block just different casting.
Have 89mm stroke (crower crank) by using a longer rod to make up the for the additional deck height would give me a higher R/S ratio letting me bump the redline a bit correct? But would not affect displacement unless i stroked correct?
I do have the option to exchange the crank for a 92mm or 84.5 mm. Car is mainly a street car (only home 5 days a month).
So going to a 92mm lowers my redline and increases displacement increase torque and power. At the cost of longevity and cylinder wall stress.
But going to the 84.5 stroke decreases displacement power and torque but gains redline correct?
Sorry i cant give R/S ratios havnt figured out rod length and such yet. Just finishing a parts list and am stuck on direction.
Thinking that going to the 92mm stroke crank in conjunction to the additional rod length do to deck height wouldnt cause additional cylinder wall stress. Maybe it would balance out like stock with a redline around 8500-9000
Also do we have a list of sponsors for performance parts? or where do you guys like to order from?
TheCrimsonGhost666
Mid-Atlantic (Sales)
Nov 6, 2012 07:53 AM
CMVTEC95
May 21, 2010 05:42 AM
b18sihatch
Jul 12, 2006 12:51 PM
SQ is the SQUAD
Oct 27, 2005 04:59 PM
boostinb20vtec
Sep 17, 2004 10:33 AM
