Has ANYone Install a JDM Heater Control
What I do know is that it is not a direct bolt in. First off it is intended for right hand drive and second is that it is 100% electric, no cables. I believe the heater box assembly needs to be sap out w/ another but then there falls the problem of being for right hand drive. I am not saying it can't be done but it does involve alot of work. good luck
hmm i was lookin at my cage today ansd i dont think it would matter.... if it was RHD or LHD.... hmm but it is eletric... hmm wat does it control then???
K you'll need 3 things. Just get them from a CRX since it's all there. All you'll need is the Climate Control, the Main Wire Harness under the dash and the Heater Core from a CRX and that's all you'll need. make sure you take it from a matching year CRX though. If you're Civic is 88-89 then take the guts from a 89 CRX Si and the same for 90-91 cuz the wire harnesses aren't the same.
i think he was thinking of the stock heater controller... for a rex not the JDM... i saw the jdm one last night adn it donest matter if it is RDH or LDH... it has the same mounting holes and the stock one... 2 holes on the left of it and one on the right of it
Has anyone succesfully done this swap?
Well if anyone plans to attempt it , I have an outside temp sensor (from the JDM front end that I purchased).
[quote] The Japanese auto-climate control has another actuator to control the temperature. Automatic temperature control is the main difference.
Has anyone succesfully done this swap? [/qoute]
seems you been researching alot do you have any helpful links???
I have a 89 CRX Si dash in my 89 Civic Si HB and all I used was the wire harness, heater core and climate control off of it and voila done. I did this cuz it looks JDM with the climate control and is better using the CRX dash cuz it bolts right in and is slanted and looks even better than doing the Teg center console or SiR center console which I had in there B4 this one.
so how do you control the fresh/recirc air? or did you just disconnect it? do you have any pictures? so you just used a crx dash with the matching climate control? how does that "look jdm"? it just looks like a normal crx right?
iNetForce
Apr 3, 2004 07:34 PM
