Suspension & Brakes Theory, alignment, spring rates....
Track / street suspension
Old Apr 13, 2011 | 11:20 AM
BLaCKWiDoWSi's Avatar
Default Track / street suspension
Okay what are some of you guys using as far full coilovers for the street and occasional use at the 1/4 mile? We take the car to the drag strip and we drive on the streets. I'm not planning on making it strictly drag cause we want to enjoy it on the streets so I'm not looking for 12k/18k spring rates. Just something that when we take to the track I can raise the rear up and stiffen up the front some to take away some squatting at the line. Anyone using buddy club coilovers? Any suggestions please!
Old Apr 13, 2011 | 11:59 AM
TunerN00b's Avatar
Default Re: Track / street suspension
Originally Posted by BLaCKWiDoWSi
Okay what are some of you guys using as far full coilovers for the street and occasional use at the track? We take the car to the track and we drive on the streets. I'm not planning on making it strictly drag cause we want to enjoy it on the streets so I'm not looking for 12k/18k spring rates. Just something that when we take to the track I can raise the rear up and stiffen up the front some to take away some squatting at the line. Anyone using buddy club coilovers? Any suggestions please!
You might want to actually explain what you intend to do with it. First, you list track and street, then mention drag racing...
And you don't want to adjust the height of the rear end at the strip without an alignment, as the toe will be off afterward.
Old Apr 13, 2011 | 12:49 PM
Sorry. Meant to say 1/4 mile. I'm not going to raise the car at the track. I'm just saying when I prep the car for the track I can raise the rear end. My friend owns an alignment machine so it's not a problem for me to get it aligned. But yeah 1/4 mile and street use is my intentions
Old Apr 13, 2011 | 01:02 PM
TunerN00b's Avatar
What benefit does raising the rear end of a FWD car provide at the strip?
If you want to reduce launch squat, you want stiff rear springs. If you want street comfort, you want soft rear springs. This one is going to come down to your preference / tolerance and which activity is more important to you.
No personal experience with Buddy Club stuff.
Old Apr 22, 2011 | 01:57 PM
Greenmonster138's Avatar
I would say go with what works best on the street, that is where you will be using the car 99% of the time
Old Apr 22, 2011 | 09:02 PM
Libertariat's Avatar
Ek Forever y0!
Raising the rear height isn't going to help you at the drag strip. You need stiffer springs.
I would recommend some setup with stiff valving, probable at least 500F and maybe 400R if you want a compromise in stiff and tolerable. I've got 350 rates and I'd imagine much more than 400 really starts to get tough on rough roads.
Civic89stdB16
Suspension & Brakes
Dec 20, 2008 11:57 AM
wfocrx
Sep 14, 2006 04:11 PM
CLMTFabEG6
Suspension & Brakes
Dec 29, 2005 08:59 PM
madx
Feb 9, 2004 07:35 PM
nerces
13
Apr 16, 2003 08:48 AM
