Lifespan of the Toda/Power Enterprise Timing Belt????
Old Sep 28, 2002 | 10:40 AM
GQ 05YellowEVO8's Avatar
Default Lifespan of the Toda/Power Enterprise Timing Belt????
I was wondering how long they would last? On Toda's site it says that their belt is 200x strronger than stock, so does that mean I can leave it on the car longer?
Old Sep 28, 2002 | 11:31 AM
TimoneX's Avatar
New User
Default Re: Lifespan of the Toda/Power Enterprise Timing Belt???? (VTEC-MAN95GSR)
I certainly wouldn't, but for about $120 more than an OEM belt, it'd be nice to get something more then just a different color. I wonder if the teeth on the belt are actually stronger or if just the belt itself is stronger. If it's just as likely to strip several teeth as an OEM belt it would be completely pointless.
Old Sep 28, 2002 | 01:33 PM
Blade's Avatar
New User
http://www.todaracing.com/products/h...ming_belt.html off this link:
Resistence to cutting 3.5~4 times
Heat Resistance 2.5~3 times
Tooth Integrity 3.0~4 times
Resistance to abrasion 2.5~3 times
Old Sep 28, 2002 | 08:51 PM
TimoneX's Avatar
New User
Default Re: Lifespan of the Toda/Power Enterprise Timing Belt???? (Blade)
Perhaps you could just leave it on for the recommended 90k instead of shortening it when using aggresive cams. I think I'd rather just change it @ 60k or so and use a Honda belt for just over 1/4 the price tag. Too bad it's so dern expensive, I'd love the extra piece of mind.
Old Sep 28, 2002 | 08:57 PM
miller's Avatar
Default Re: Lifespan of the Toda/Power Enterprise Timing Belt???? (TimoneX)
i would recommend changing the bely every 10k miles or so if you are hard on hte car. i change mine on my daily driver more often then that. i guess you can say im **** with my cars.
Old Sep 28, 2002 | 09:22 PM
TimoneX's Avatar
New User
Default Re: Lifespan of the Toda/Power Enterprise Timing Belt???? (vtecdoc)
10k?!? No freaking way. I like to play it safe, but come on. I drive 10k miles in a few months. I'm still on the original timing belt with my GSR @ 81k. Put the big Crowers in at around 52k. Time to change it...yes. Am I paranoid...nope.
Old Sep 28, 2002 | 09:38 PM
Paste's Avatar
Loved
Ok the purpose of this belt, which i found in other topics just yesterday when i was looking for some info on it, it is not necessarily ment to last longer but to be a lot stronger when a more radical cam is used (i.e. Toda B or C) because it puts more strain on the belt... i think. this thread https://honda-tech.com/zerothread?id=243695 (towards the bottom) talks about why you might need to upgrade it. One guy says a stock belt should last longer that 90k miles if installed properly.
Old Sep 28, 2002 | 10:15 PM
TimoneX's Avatar
New User
Default Re: Lifespan of the Toda/Power Enterprise Timing Belt???? (paste)
Yes it most likely will last longer than 90k, but at some point it WILL break. When it breaks it WILL do some not so good things. 90k is where Honda implies the risk becomes somewhat higher. Now I wouldn't mind changing it more often, perhaps 60k or so, but I see no reason to buy a $180 belt unless they're willing to offer some kind of insurance or some other compelling reason to go with such an expensive belt. Otherwise it seems to me that just changing it 30k miles sooner and/or inspecting & retensioning it more frequently would be a better option...and allot cheaper.
Old Sep 28, 2002 | 10:54 PM
R_yd's Avatar
to me, if you have money and want the extra peace of mind then go for it. me? i wouldnt pay the extra bucks. i change my belt every 60-70k miles no matter what; and if the oem belt is installed and replaced properly there shouldnt be any worries...and i dont worry.
Old Sep 29, 2002 | 12:12 PM
Default Re: Lifespan of the Toda/Power Enterprise Timing Belt???? (Rspool)
thanks for the repluies guys
Old Sep 29, 2002 | 03:04 PM
Shark Tank's Avatar
my oem belt lasted 26k miles before the teeth went bye bye thanks to spec b's. we'll see how long this next belt lasts
Old May 27, 2003 | 05:40 AM
R3dL1n3's Avatar
Default Re: Lifespan of the Toda/Power Enterprise Timing Belt???? (Shark Tank)
SO these belts do not neccesarily last longer that the OEM belts eventhought they r stronger?
doesnt make any sense??
How often would you guys, with high lift cams change timing belts(PE/Toda) then?(60K miles?)
Old May 27, 2003 | 10:40 AM
s2k420's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shark Tank &raquo;</TD></TR><TR><TD CLASS="quote">my oem belt lasted 26k miles before the teeth went bye bye thanks to spec b's. we'll see how long this next belt lasts &lt;IMG NAME="icon" SRC="http://images.zeroforum.com/smile/emwink.gif" BORDER="0"&gt; </TD></TR></TABLE> Now in shark's situation i think you would want to go with the Toda Timing belt
Old May 27, 2003 | 10:58 AM
Austin's Avatar
Default Re: Lifespan of the Toda/Power Enterprise Timing Belt???? (JDmMugeNItR)
The Power Enterprise belt is a Kevlar reinforced belt, quite nice...and I had a very good conversation with the owner of the company that's a Mechanical Engineer from Japan while I was at IAS, their booth was right across from HyTech's booth that I was working at.
Austin
p.s. he said that it was a "trade secret" if he made the belt for anyone else
Old May 27, 2003 | 11:35 AM
OBDI JEDI's Avatar
Default Re: Lifespan of the Toda/Power Enterprise Timing Belt???? (Austin)
anyone running spec B's with the stock timing belt, i just changed my timing belt 3000 miles ago and i really dont want to have to change it again.
Old May 27, 2003 | 03:14 PM
euclid's Avatar
Default Re: Lifespan of the Toda/Power Enterprise Timing Belt???? (OBDI JEDI)
if you have a stock valvetrain i would assume there is no need for this toda belt at all, but if you are running aftermarket cams and springs i would think this upgrade is a given. 100$ more for belt that is strong enough to handle the increased strain is well worth it imho, think about how much you spent on the valvtrain alone.
gosu08
Feb 11, 2010 05:01 PM
ALLxMotor DA
Sep 6, 2008 06:10 AM
MCP486
Apr 20, 2003 02:02 PM
rated_r
Nov 14, 2002 12:13 PM
fred92htch
Jun 19, 2002 11:56 AM
