f23 replacement running weird...
Yea so the f23 swap is finished other than one problem that Im not realy having much luck on. Here is some info on my set up on the cb7...
F23a1 w/60k miles
f22a6 dizzy w/external coil(new cap, new rotor, new plugs, new plug wires)
f22b1 manifold w/injectors
POA ecu from a 94
auto to manual conversion.....
going to be boosting soon
The car starts up and idles but isnt smooth. It has a miss of some sort. I only have one cel code which is 21(vtec isnt wired yet)
It takes throttle fine and clears up after about 2500 or so. just sounds like **** and acts like it wants to stall at idle.
compression is 180psi on all 4 cylinders.
The f22 decided to throw a rod at 350k and this was just a cheap replacement i got from a friends honda graveyard for cheap.
Any ideas?
F23a1 w/60k miles
POA ecu from a 94
Any ideas?
Coltmorris
12
Feb 9, 2007 09:13 AM
