wideband showing running lean
Old Apr 12, 2011 | 06:29 PM
protopro88's Avatar
Default wideband showing running lean
Well i cracked a cylinder wall which caused a ton of coolant to rush through my exhaust. I fixed the motor and the car started right up. When im accelerating the wideband goes to 16-17:1 would the coolant have ruined the sensor causing it to give a false reading?
Old Apr 12, 2011 | 06:37 PM
2k.civic.si's Avatar
Default Re: wideband showing running lean
replace the sensor and you will know your answer.
Old Apr 12, 2011 | 06:41 PM
protopro88's Avatar
Thanks for the help man haha. Im going to do that right now
Old Apr 12, 2011 | 07:20 PM
SovXietday's Avatar
Sensor sounds damaged to me, engines generally won't even run near smooth at load at 17AFR if at all.
Old Apr 12, 2011 | 07:45 PM
ohsnapzafingcu's Avatar
I serve phở for my babies
got any exhaust leaks?
Old Apr 12, 2011 | 10:53 PM
W!d3b0dYr3X's Avatar
Test the sensor before wasting 80 bucks its not hard. Take a rag, soak in carb cleaner, stick sensor in if it goes full rich and stays for a long time sensor is good, if it goes full rich and starts going lean after a short amount of time sensor is bad
nfereorhatch
Nov 24, 2008 04:44 AM
ion_four
Sep 23, 2003 12:28 PM
BlackGSR87
Mar 7, 2003 08:45 AM
LB CRX
Aug 15, 2002 04:24 PM
