d16y8 block d16z6 head...no start
Old Apr 12, 2011 | 06:27 PM
civicsedan89's Avatar
Default d16y8 block d16z6 head...no start
hey guys i just did a d16y8/z6 head swap into my ef...everything is connected as it should be but it doesnt start...it cranks...does the timing order change from the y8 since its a z6 head??? any help would be appreciated...thanks
Old Apr 12, 2011 | 10:31 PM
24TEN's Avatar
PHANTOM MENACE
Default Re: d16y8 block d16z6 head...no start
Firing order is the same, mechanical timing is a bit different. Did you use a Z6 specific camshaft and camgear?
Old Apr 15, 2011 | 02:59 PM
yea i did...i figured out theres no spark...idk what it could be...main relay?fried ecu?how can i tell if my ecu is bad?
Old Apr 15, 2011 | 03:10 PM
4drEF's Avatar
Keyboard Humorist
More than likely it's your distributor wiring or something in the distributor itself.
What distributor and ECU are you using?
Main relay has nothing to do with it unless your ECU isn't getting power.
Old Apr 15, 2011 | 04:24 PM
widewhite's Avatar
sounds like dizzy issues
Old Apr 18, 2011 | 07:49 PM
im using a p28 ecu and a td42u dizzy
Old Apr 19, 2011 | 07:55 AM
4drEF's Avatar
Keyboard Humorist
Make sure your ground cables are good. Especially the ones that go from the chassis to the transmission/motor.
Other than that it really sounds like the distributor.
92civicsi
Apr 4, 2011 01:54 PM
wickedj05
Feb 1, 2010 06:10 PM
Eyal 951
Jul 16, 2006 05:59 PM
CRXb16asir91
Mar 30, 2003 09:22 PM
vtecrx
Nov 8, 2002 05:18 PM
