Can you problem solve this?
Old Apr 12, 2011 | 04:39 PM
dmrush1's Avatar
Icon2 Can you problem solve this?
I have a 99 Accord, manual transmission. Over the past few months, about 4-5 times, while driving, the engine will be running smoothly and then lose power for a split second(RPMs will go down), but not turn off and then continue to run smoothly for a few more weeks until it happens again. Lately, when starting the car, it will seem to start (sound and RPMs) as I turn the key, but as soon as I turn the key back, it will die. After a few times of this, it will adventually start. I've tried changing spark plugs. Any thought about what it might be?
Old Apr 12, 2011 | 04:57 PM
phootbag's Avatar
Default Re: Can you problem solve this?
Faulty ignition switch.
Old Apr 12, 2011 | 05:35 PM
poorman212's Avatar
^ agreed...I swear I just saw this post somewhere...oh well, I guess short term memory problems can be a blessing....but wait, I did.
To the OP, that is about four or five answers, all saying the same......good luck.
Old Apr 14, 2011 | 05:30 AM
dmrush1's Avatar
Thank you for your help-I'll try to replace the switch.
dmrush1's Avatar
Does that have anything to do with the momentary lose of power while cruising? Are they 3 separate issues appearing at the same time?
Old Apr 14, 2011 | 05:50 AM
Heat's Avatar
There was a recall on the ignition switch on this Accord, back in maybe '02 or '03. Call the dealer with your VIN and ask if there are any open recalls on it.
If you end up doing it yourself, here is a good tutorial:
https://honda-tech.com/forums/honda-accord-1990-2002-2/1998-2002-honda-accord-ignition-switch-replacement-2353017/
(pictures aren't showing up for me, I don't know if they are gone or if my internet security is blocking the host site)
Old Apr 14, 2011 | 05:58 PM
poorman212's Avatar
Start with testing/replacing the switch, I'll bet the momentary lose of power while cruising will go away.....if not we'll need a little more detail about what you mean by that and the situation by which it happens.
Old Apr 14, 2011 | 07:38 PM
singlecamsaint's Avatar
these switches seem to be a common problem among accords are preludes this way to
Old Apr 18, 2011 | 04:52 PM
dmrush1's Avatar
That's a very good tutorial. I'll look into it this weekend. Thank you everyone for your help!
Old Apr 24, 2011 | 04:52 PM
dmrush1's Avatar
I called Honda, and they said that it was already replaced, but they can do it again! Yeah for Honda!
hondalion
Jun 25, 2013 06:21 AM
LS1SSM6
Aug 25, 2011 05:51 AM
scotthoward
Jul 17, 2010 04:31 PM
JDW
Jul 3, 2010 05:36 PM
95greenlude
Dec 24, 2007 07:01 AM
