where does this vacuum go?
Its of my integra 91 not sure if this is the ls motor from newer integra dc?
but i need to know where this vacuum goes my car idles kinda funny, i think this vacuum might be the problem but i don't know where it goes to?
ps its coming out of the censor type thing on the right.
[IMG]
[/IMG]
[IMG]
[/IMG]
that would be the air boost valve and i believe i see a cold air intake?
well that hose goes to the pipping which then goes to the stock intake system. I have it the same way and it goes no where
here is a vacuum diagram
http://hondaswap.com/attachments/132...vacuumdiag.gif
do you get code 12 (EGR)? I get the code, my car is an automatic which has an EGR valve but the manifold which was replaced came from a manual and has no spot for an EGR and thats the reason i get the code. You should not have this issue with that. For a bad idle i'd look at cleaning the Idle Air Control Valve located on the back of the manifold, you can easily find a guide on how to do that by googling it, and cleaning the FITA, Fast Idle Thermo Valve and when you do these make sure you let your car relearn the idle by removing the negative battery terminal for a little then when you go to start it let it idle for about 10 mins without touching the gas. see if that will solve your issue with your idle
yea i do have after market intake short ram, so what does the air boost valve do?
im not sure what code it is haven't check it..and the check engine turns on randomly,
and i will check that idle valve in the back of the manifold ill let u know what i find
thnx-
thnx-
That is the daspot diaphragm. It is supposed to keep your throttle plate from slamming closed when you let off of the gas. It shouldnt be causing your idle problems. It dosent need to be hooked up. Actually you can remove the dashpot all together if you want.
rlacsamana1989
Feb 27, 2012 10:18 PM
TypeR0207
13
May 29, 2002 06:12 AM
