Problem removing front lower control arms - bolt spins
The lower control arm uses long bolts with nuts at the end. You need to hold the nut with another wrench while taking the bolt off. After that, if it just spins inside the bushing, use a screw driver/pin to knock it out.
OP I had this happen to me, I ended up replacing the subframe instead of cutting a hole in it to get at the welded nut.
I held it with vice grips and loosened the nut with a wrench. It took a while but I finally got it done.
Also, be careful with damaging the threads.
myownreality
Feb 9, 2013 10:43 PM
Tong.Y
Jun 14, 2010 12:33 AM
