coilovers
- Cut the springs (dumb)
- Cut the rear shocks' spring perches (dumb)
- Remove the coilover sleeve's spring perches/locking rings and combine with above if desired (dumb & dumberer)
- Toss those garbage coilovers and get a made-in-China full coilover setup with shortened damper bodies (not as dumb but not great either)
- Go with a better coilover setup like Skunk2 Pro-S II's or Progress CS-II's, but you might need to get shorter springs to get lower
- Go with Koni/GC and use 450 lb/in or higher 6" springs in the back.
Those are pretty much your options
It's really easy, look through here and see what setups people are using:
https://honda-tech.com/forums/suspension-brakes-54/slammed-suspension-setups-2077238/
