Are d15b7 and d16z6 distributer's internal coils interchangeable?
I have a b7 dizzy half hanging on my z6 engine and I need a real z6 dizzy. Local guy has one for 20 with a bad coil. Is this swap possible?
'97 - '01 CR-V's too.
im pretty sure all of them are the same (b,d,f,and h obd1 and obd2) ive swapped parts from all of them into other housings. housings are whats different
this is awful weird, because I am running a z6 dizzy in my b7 head. Runs fine and bolts up perfectly.(before anyone asks) yes it's a true z6 dizzy considering it came factory in my 95 ex sedan with a d16z6. Also fit in my y5 and bolted up correctly and ran fine
It shouldn't... so how about getting a photo posted up to show us AND tell us what housing number you have. It is a 5-digit code found on the edge of the housing facing the front of the car. It will be TD-XXU... the "XX" will be the housing number.
1SickEG
Oct 9, 2006 12:00 AM
HiProfile
Jul 25, 2005 09:21 PM
change, coil, d15b7, d15b8, d16z6, distributor, dizzy, interchangable, interchangeable, internals, obd1, obd2, pack, parts, z6
