manual trans adjustment?
I have a 04 LX manual (1.7L). I am having trouble getting the trans into reverse and sometimes it "pops" out while in motion. Is there a way to adjust this?
Go to a GM dealership and get "Synchromesh" manual transmission fluid.... I am not joking here... get the GM fluid.
Go to your shift linkage where it means the transmission. Pull the cotter pins and gently disassemble the bushings there, clean and re grease them. Have a buddy shift between gears and watch the action of the shift linkage. Your issue could also be related to the clutch although less likely if you are only have trouble with reverse. The shift cables can stretch out somewhat or become corroded.
Did you have issues prior to using the GM?
I had some issues with second gear synchro before switch to synchromesh. Went from OEM honda to GM and had positive result right away. No gear clash since... only been about 1000 km so far tho. Seemed to smooth out shifts and engagement for me personally?
I've read those as well. It's why I tried it. After I flushed and filled with synchromesh the trans starting clicking while turning right in second gear, which is a known problem for our cars. It was designed and made for trucks. Not a Honda.
Uncle Seth
Feb 12, 2018 12:44 AM
