97 Civic Hatch AC belt removal
Old Apr 12, 2011 | 08:27 AM
LeonardDB's Avatar
Default 97 Civic Hatch AC belt removal
I need to change the belt. There is a engine mount shaft running from the AC compressor under the body frame. The AC belt goes around the mount shaft. Do I have to remove the compressor mount bolts? How do I get the belt off with minimal work?
Old Apr 12, 2011 | 11:01 AM
alphalanos's Avatar
Default Re: 97 Civic Hatch AC belt removal
I just support the engine with a block of wood on a jack and unbolt the mount. lift the engine enough to slip the belt through and replace. then lower the engine and tighten the mount.
Old Apr 13, 2011 | 04:12 AM
LeonardDB's Avatar
alphalanos, thanks for the reply. I searched thru old posts and could not find the answer but did find the solution late yesterday in old posts. The lower engine mount (half-moon shape), drivers side, has to be removed to change the AC belt. To remove the mount: Remove the 19mm mount shaft bolt, Remove the (2) 14mm bolts on the mount. The mount will slide off. Change the AC belt.
Old Mar 9, 2013 | 12:16 PM
JJT211's Avatar
Would be really nice if someone could put this in the FAQ
MelJ
13
Dec 10, 2010 06:25 PM
keeprollingon
Aug 3, 2008 05:27 PM
hondaless
Dec 31, 2005 03:24 PM
danteisme
Feb 20, 2005 08:39 PM
reeder321
Feb 2, 2005 03:44 PM
