my timing is retarded
Old Sep 28, 2002 | 09:25 AM
aet6's Avatar
Default my timing is retarded
With the timing light at 16 deg., it appears my timing is ~4 deg.
I had lately noticed the car running like crap, so started checking things...
So, I tried to change the timing.
I cannot physically move the distributor enough to increase it to more than about 8 deg.
Can anyone elaborate on how you "reset" this?
I'm assuming I take the distributor off, reset to 16, put it back on, but if anyone has done this and could expand on the process a bit?
Or, if anyone could tell me why this is the WRONG thing to be doing, and what I should be doing instead?
(I know I'll get these comments anyway, might as well ask for 'em)
Also, how does this happen?
What would cause the timing to be so off??
Thanks for any help!!
aet
Old Sep 28, 2002 | 10:26 AM
MackSpeed-616's Avatar
Default Re: my timing is retarded (aet6)
do you have aftermarket cams, or adj. cam gears or anything?
Old Sep 28, 2002 | 10:50 AM
Def's Avatar
Def
Default Re: my timing is retarded (BustaNutt-616)
If you really need to advance it that much. I have heard(and seen) of people "slotting" the bolt holes with a large drill bit. Remove as much material as you need.
Old Sep 28, 2002 | 11:32 AM
tonyxcom's Avatar
Default Re: my timing is retarded (Def)
do you have the short on the service check connector?
Old Sep 28, 2002 | 02:15 PM
Hooch'n's Avatar
Default Re: my timing is retarded (tonyxcom)
time to boost!!!!!!!!!!
Old Sep 28, 2002 | 05:06 PM
chad's Avatar
Moderator
Default Re: my timing is retarded (Hooch at 8400-RPM)
you said We-Todd-Did.....uh huh
Old Sep 28, 2002 | 06:21 PM
aet6's Avatar
Default Re: my timing is retarded (Chad)
To clarify a few things...
car is stock.
we set piston #1 to tdc and none of the timing marks lined up with the pointer.
all i can figure is the timing belt slipped, and indeed the timing belt is not as tight as it needs to be
i could have pulled it off the cam gears
and yes, the service connector was jumped.
and yeah, i said we-todd-did
aet
tctruong94
Apr 27, 2017 11:10 AM
bopbop93030
Feb 24, 2009 02:57 PM
allnaturalb16
21
Aug 14, 2007 08:57 PM
johnbrooke86
Aug 23, 2004 04:49 PM
mini-v-si
Jun 22, 2004 09:36 AM
