TW: Built turbo d16z6 setup
I'm thinking about switching setups. I have a built d16z6. This is what's done to it, and what will be sold all together:
*Block
Bored to 75.5mm, w/ stock sleeves
ACL bearings
Kings thrust washers
Scatt H-beam rods w/ ARP rod bolts
Vitara pistons
Honda water pump
Honda oil pump
Honda head gasket
Rotating assembly balanced
Block notched for rod clearance
Comp Clutch stg 4 6 puck
ARP head studs
*Head
Supertech spings & retainers
Honda Keepers
Stock Valves
3 angle valve job
Crower turbo cam
AEM adj cam gear
Stock ports
Z6 IM w/ H23 tb (port matched)
Precission 780cc inj w/ resistor box
DSS axles
Stock Z6 trans
Avid poly mounts for EG
Custom mini ram turbo mani w/ 38 mm w/g flange and T3 flange
Custom 4 bolt 3" dp
Go-autoworks dt
Garrett T3/T4 .57 trim
*all machine work done at Marty Browns Racing and Machine shop
Setup has about 4k on it. Runs great. Setup went 12.7 @ 117 on 18 psi, w/ slicks, on street tune.
Make an offer. I am not parting out.
*Block
ACL bearings
Vitara pistons
Honda water pump
Honda oil pump
Honda head gasket
ARP head studs
*Head
Honda Keepers
Stock Valves
3 angle valve job
Crower turbo cam
AEM adj cam gear
Stock ports
DSS axles
Stock Z6 trans
Custom 4 bolt 3" dp
Go-autoworks dt
A sleeved b series block w/ internals n balanced rotating assembly, trans, twin disc, mounts, shift linkage, turbo mani (full ram/top mount), dp, dt. I have a head
beginmyhonda
May 1, 2011 08:05 AM
b18_ef_hatch
Appearance Build Threads
61
Apr 20, 2010 07:42 PM
