d16y8 chucked a rod through the block - what block replacement?
Old Apr 12, 2011 | 06:17 AM
fallrivercolin's Avatar
Default d16y8 chucked a rod through the block - what block replacement?
I've got an ej8 here that chucked a rod through the block, and I'm wondering what kinds of problems I will run into if i end up putting the y8 head on a different block. This is my first time messing with a d-series. Are there any sensors on the other d series bottom ends that will have to be wired differently? I know most of the sensors on our cars are on the top end, which won't be changing so that is fine. The car is a CANADIAN si coupe with a/c, p/s, cruise and the works. So i guess the real question is, what are my options for bottom ends, and what is the difference between the y8 bottom end and say the z6 and y7's.
Old Apr 12, 2011 | 06:53 AM
94EG8's Avatar
Seagull Management
Default Re: d16y8 chucked a rod through the block - what block replacement?
Y7 bottom end is basically the same. Z6 has a better crank than the Y7/Y8 and due to double the amount of oiling holes.
Old Apr 12, 2011 | 07:44 AM
Bizzle5OH3's Avatar
Go with the Z6 block
Old Apr 12, 2011 | 07:53 AM
EJeff8's Avatar
If you want it just plug and play though, A y7 block will be the easiest to deal with. The Z6 doesn't come with a knock sensor hole and unless you run a p28, you'll never have Vtec.
Old Apr 12, 2011 | 12:45 PM
So the stock si computer (p2p isnt it?) won't work with a z6 block?
Old Apr 12, 2011 | 02:00 PM
EJeff8's Avatar
You'll be missing sensors. If you go with a P28 though, it should resolve the issue.
Old Apr 12, 2011 | 04:51 PM
Kista20's Avatar
y5 bottom end would also be a good choice if you can find one, basically the same thing more or less comparable to the y8.
evanguy
10
Jun 1, 2011 06:35 AM
4g4dcruisin
25
Jun 30, 2010 06:30 AM
Novtec4u
Jun 15, 2009 09:05 AM
AgentJam
Feb 20, 2004 09:49 AM
