Cooling system problem on EM1
Old Apr 11, 2011 | 09:23 PM
JDMloveDSMkilla's Avatar
Default Cooling system problem on EM1
so i just finished putting my car together from an accident and i bought a new radiator. i filled the radiator and the resovoir and started the car to burp the system and it didnt seem to do anything. the upper hose got hot after awhile and the lower hose was cold. What are some options that i could look for to fix this? also bought a new fan which didnt turn on when the temperature rose...
Old Apr 12, 2011 | 06:21 AM
fcm's Avatar
fcm
Old Fart
Default Re: Cooling system problem on EM1
I would check the thermostat, [lower hose cold] it sounds like it is stuck closed.
The rad fan should turn on when engine coolant reaches 190-200 degrees F, if it is not you will need to check the rad fan circuit.
What is the MM&Y of your car, is the it stock? 94
progekSiR
Apr 22, 2012 11:50 AM
AlfieRoach
17
Jan 17, 2010 08:25 PM
jeremyrocksursox
Aug 27, 2009 07:29 PM
Dat1BVtecN
Mar 8, 2007 06:55 PM
PreIudeSI
Aug 24, 2004 09:55 PM
