need help bad wit a 96 jdm b20b swapped into 98 hx
Old Apr 11, 2011 | 06:28 PM
98 hx jdm b20b's Avatar
Icon2 need help bad wit a 96 jdm b20b swapped into 98 hx
first off im new to forums and to tuners, i have a 1998 civic hx with a jdm b20b running off a ls ecu and when i tryed to hookup my mechanics computer wit the program "auto enginuity" through the obd2 plug it said it couldnt communicate and then i tryed my actron code reader and it said link error so i tested the female plug in my car n it has power so now im lost........will a US version scanner scan a jdm motor ????? and will the ma inspection station be able to scan obd2 to pass it ???????? even tho its a jdm b20b motor ??? ...........help plz any info is helpful.......
Old Apr 11, 2011 | 07:17 PM
94EG8's Avatar
Seagull Management
Default Re: need help bad wit a 96 jdm b20b swapped into 98 hx
JDM OBD2 ECUs wont communicate with a scan tool, you'll need to run a USDM ECU and make sure you're running a secondary O2 sensor and perform the CKF trick shown here -> http://technet.ff-squad.com/ckftrick.htm
Old May 5, 2011 | 11:46 PM
hatch 96's Avatar
do any of you guys know a spot to fake the emissions?
Old May 6, 2011 | 12:10 AM
lazlong's Avatar
^^ Looks like somebody likes felonies.
Old May 6, 2011 | 01:21 AM
HondaPartsHero's Avatar
Technical Hero
just get an US OBD2 LS ECU, should be relatively cheap and abundant
Old May 6, 2011 | 05:27 AM
TaffetaEj6's Avatar
you are an idiot
vboy714
May 10, 2005 05:04 AM
EE_Chris
Jun 12, 2004 02:43 PM
EE_Chris
May 31, 2004 10:25 AM
silvershiny-ek
May 15, 2003 08:00 AM
