Power-steering question
Old Apr 11, 2011 | 06:01 PM
hbcrazy88's Avatar
Default Power-steering question
I removed my PS so now my PS pressure switch is just dangiling. Can I just depin the two wires to remove it completely?
Old Apr 12, 2011 | 02:00 AM
truckboy's Avatar
Default Re: Power-steering question
First of all check the power steering fluid, or may this problem is because of worn steering gear or loose suspension belt. check the noise in the steering pump, if getting whine and loud noise then may be belt is sleeping, check whether steering pump fluid is leaking or not.
Old Apr 12, 2011 | 04:48 PM
mnhatchback's Avatar
Okay? You removed ur ps steering pump of the right of ur motor by the ac? If so just zip tie the wires back further. Also you should look into making ur power steering a closed loop. It still has fluid in the lines and makes steering a little bit easier. Did you remove it for a turbo? What are you gonna be running?
Old Apr 12, 2011 | 04:54 PM
Loose suspension belt? Is that on the level of muffler bearing
Old Apr 13, 2011 | 04:49 PM
hbcrazy88's Avatar
i have already looped the system. the reason why im asking, is because a sensor broke off of my engine harness and the PSPS plug matches it. So i was wondering if i could cut off the PSPS and not have anything to worrie about?
Old Apr 14, 2011 | 08:54 AM
CleanLikeJdm's Avatar
Hype-R Stalker
If you never plan on using it again, just take it out completely.
Old Apr 18, 2011 | 04:13 AM
Oh yeah just depin it and put something on the wires so there not bare and short out. Good luck.
sneekz206
Feb 1, 2011 03:41 PM
b20beast83
Oct 21, 2008 12:27 PM
94sirintegraGP
Sep 20, 2008 12:23 PM
ibme_uk
Jan 6, 2005 08:23 AM
