Turn Signal Trouble
Old Apr 11, 2011 | 01:47 PM
MrGiggles's Avatar
Default Turn Signal Trouble
I'm having a little problem with my turn signals.
The left side signal works just fine. The bottom housing on the bumper has a bad bulb so it's a little fast but works fine. The right signal doesn't work at all, but when I push the hazard button both sides light up just like they should. I thought this was the signal switch, so I replaced it but the problem still persists.
Is there a common failure with this system? Also, how would I go about troubleshooting the problem.
Old Apr 14, 2011 | 12:53 PM
MrGiggles's Avatar
Default Re: Turn Signal Trouble
Changed flasher relay, no change.
and bump.
polaris80
Apr 20, 2007 04:13 AM
ZipTieGUy
Feb 8, 2006 08:26 PM
SaTownTegGsr
Aug 20, 2004 11:45 PM
dbest1
May 19, 2004 05:51 AM
Itoe
Dec 10, 2001 05:42 PM
