Turbo ?
Hello everyone, i just recentley finished my turbo R and im just waiting for my electronic boost controller to arrive. My question is would it be ok to turn on the car without the boost controller, some people tell me yes some say no. im a little confused cause never had a boosted car before. Thanks
You can run it, but I wouldn't push it too hard yet. Without a boost controller, the wastegate will most likely open before the desired boost pressure is reached, and you'll end up with pretty bad turbo lag.
anyway, to the op, the dangerous part about your post is not telling us which turbo it is, what wastegate spring you have or if it was tuned for the boost level of your spring. if your car wasn't tuned for that EXACT combo, don't drive it.
it should be almost common knowledge by now, if you're going to turbo an R, you don't pressurize the motor until you tune it. that means you drive to the tuner on your p73 ecu and stock injectors and either don't connect the intake tube or leave the BOV off so it won't pressurize. could pull the WG spring too
I meant with an average spring rated for 7 bar, without a controller it wouldn't get up past 3.5 bar, and it'd be shitty to drive. Just saying generally. Don't know about R's though.
a .7 bar spring will release boost at .7 bar, the controller would allow .7+ bar
I don't have a type r but I just built my Ls vtec engine and slapped a Garret on it. I don't have a boost controller at all but I just got mine in the mail. I drove around just fine for 2 weeks but I didn't let it rev past 4k rpms. It felt pretty normal and my engine is still good but it might just be that I'm lucky! Just my 2 cents. Hopefully you get a straight answer!
As of right now i dont have any tune on it just a virgin p28, 1000rc inj, gt35r, 38mm tial waste gate and a greddy blow off valve i have no idea what spring is in the waste gate, i just really wanna know if i can turn it on and maybe rev a couple times in neutral without out it BLOWING UP.
I truly hope you don't have that wastegate opening up and dumping into the radiator. That's just killing equipment. IS there a proper dumptube on this car?
Yes i do how a dump pipe for the wastegate its just not on right now im doing a lil cutting and welding to get a nicer bend on it.I did have to cut a small portion on the block to put this turbo but nothing major, as for the brand of manifold i bought off a friend i gots to ask him.
im having a little trouble with my injector wiring im not sure if to wire it up obd1 or obd2 im using a piggy back from obd2b to obd1 so not sure how to wire up the injectors please help.
On my turbo LS setup i started my car before the boost controller was installed... make sure you unplug your ecm/pcm fuse and build oil pressure for the first start... then just let it idle for about 5 min to try to execute an idle learn procedure... a few revs wont be bad to dont go crazy until your setup with the boost controller... i used a gt25r for my setup, gt35r sounds a little big for a 1.8L running low boost? im guessing with stock internals?... GL with the build though
there was a thread a few months back asking if the dude turbo'd his R, would it blow up
