B16A install help
My friend got a obd1 B16A with a GSR tranny & LSD. What does he need to make this work as far as wiring goes. It's going in a 98 Civic DX hatch.
the guy that installed it used the dx harness so will it work with a OBD II to OBD ! adaptor and a ECU???
Thanks Kamin!
[Modified by Boost Pressure, 2:31 PM 9/28/2002]
Thanks Kamin!
what ecu are you gonna use
well actually it dosent matter.
you can use the DX harness but you have to run a vtec wire. (using the OBDI gsr harness will cause nothing but problems on an OBDII car)
you are also gonna need an OBDII to OBDI conversion harness because your gonna need an obdI ecu.
EKcivicEK
Oct 25, 2009 09:00 AM
savestheday13x2
16
Feb 1, 2005 06:36 AM
LSvtechatch97
Oct 15, 2004 04:30 AM
VTEC5700rpm
Apr 29, 2001 03:47 PM
