01 accord fuel cut at 4k
Old Apr 11, 2011 | 06:15 AM
jarol220's Avatar
Default 01 accord fuel cut at 4k
I curently have 01 accord in our shop with a bit of an issue. We just did a clutch on it. It was easier for us to drop the subframe. After we put the new clutch in and bolted the subframe back up and hooked the harness back together we started the car and the fan kicked on without any thing being on in the dash. also it through a code for vtec system failure p1259. Anyway we took the car out for a drive and the car has a 4k cut off it will not rev past 4 grand. Any ideas on what the problem might be? I hooked up gall grounds but maybe im missing somthing? any imput would be great!!!
Old Apr 11, 2011 | 09:36 AM
jarol220's Avatar
Default Re: 01 accord fuel cut at 4k
I think it's the grounds but I have checked them twice any ideas???
Old Apr 11, 2011 | 09:44 AM
Luis.'s Avatar
Its in limp mode, are there any CELs?
Double check your wiring and ECU, is the ECU correct for your wire harness/motor?
Old Apr 11, 2011 | 10:03 AM
jarol220's Avatar
Well if limp mode cuts in at 4k then yes and yes there is a cel only one code though p1259 vtec system failure. ecu was never unpluged from the body just did a clutch not a swap
bigmaccrew
Engine Management and Tuning
12
Oct 7, 2018 08:20 PM
joeyinkc
Apr 24, 2013 08:59 AM
J240sx
11
Jan 11, 2010 06:06 PM
novakane2778
Jun 16, 2008 11:26 AM
tmkpres
Feb 6, 2003 04:06 PM
