car not cranking?
Old Apr 10, 2011 | 07:04 PM
westcoasthonda's Avatar
Default car not cranking?
battery is good and so is the starter,when i try to start it i hear a humming sound and one click? its a 97 accord,im thinking the aftermarket alarm may have to do with it
Old Apr 10, 2011 | 08:40 PM
djkurious's Avatar
Default Re: car not cranking?
Unplug the alarm (probably under the dash, drivers side) and see if it starts. Could be the relay on the starter disable from the alarm. Is this the location you are hearing the humming sound?
Old Apr 10, 2011 | 10:38 PM
ya i unplugged it and im hearing the noise from some where in the dash area
Old Apr 11, 2011 | 03:39 PM
poorman212's Avatar
Is the noise coming from the Left/driver or right/pass side....while you are at it, check the grounds.
What voltage reading do you have at the battery. What is the voltage at the large cable on the starter, both at rest and while trying to start. Then, while trying to start what is the voltage on the small wire at the starter...
Old Feb 11, 2014 | 03:29 PM
wnp94's Avatar
did you find out?
crash232
Honda Civic (2001 - 2005)
May 20, 2009 10:34 PM
tomu06
16
Mar 30, 2006 01:10 PM
tomu06
Mar 29, 2006 09:38 PM
RUBZERK
Sep 16, 2004 01:38 PM
dumbchild
Sep 4, 2002 10:52 AM
