Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
p1298 and p0141
Old Apr 10, 2011 | 06:41 PM
thatmexican32's Avatar
Default p1298 and p0141
i did a automatic to manual swap and i swapped some wire harnesses and now im getting those codes.p0141 says its O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 2) and p1298 is electric load detector circut input high.for the tranny swap i changed all the harnesses the engine bay.so today i went back and put the old harness on to see if there was a bad wire or ground.the car is the same.my rpms gauge dont work.no fuses are blown.i took the dash apart again to make sure i didnt let any grounds or wires un plugged.the o2 sensor was brand new before i did the swap so im guessing its not but im getting one off my uncles car to make sure.the next thing i was thinking of doing was changing the eld.can someone please help me with what they think it could be.i want to get my car running for sunday for honday day
Old Apr 11, 2011 | 10:13 AM
It Wasn't Me's Avatar
Default Re: p1298 and p0141
.. and now? You make it sound like you recently did this swap. According to your history, you did the swap 9-3-2010. https://honda-tech.com/forums/honda-civic-2001-2005-78/em2-auto-manual-swap-wont-get-spark-coils-2830805/
P1298
1. Reset the ECU.
2. Start the engine.
3. Turn the headlights on.
Is DTC P1298 indicated? (again)
Yes - Rather than walk you through the rest of the troubleshooting, just replace the ELD.
No - Intermittent failure. The system is okay, but you should check for poor connections or loose terminals at the ELD and at the ECU.
Old Apr 11, 2011 | 05:01 PM
yeah well i started the swap back then and with school i hadnt had time to put my car back together.
i already cleared the ecu many times after checking connections and it the code comes back in about 30 seconds.i will check tomorrow the ho2s output and im going to try to test the eld
Old Apr 11, 2011 | 10:45 PM
To be honest, I didn't think you were going to reply.
To check the ELD / Troubleshoot P1298, click this link and follow the DIY steps.
Old Apr 12, 2011 | 06:00 PM
na man i need all the help i need to get rid of the codes.thanks im going check the eld with those steps
Old Apr 24, 2011 | 01:51 PM
ok so i changed the eld and i got rid of the p1298 but now i cant find the problem to
p0141.tomorrow im going to change my o2 sensor and see if thats it but what other things can be giving me that code?
Old Apr 24, 2011 | 08:56 PM
What year is your car?
You could try running a defouler, before you commit to buying a new sensor. It'd be a lot cheaper and may prevent the MIL from coming back on.
I'd also try troubleshooting the cause before replacing the sensor.
Are you going to use an OEM sensor, or rig up an aftermarket one?
Old May 10, 2011 | 05:39 PM
my car is a 2002 with the d17
well i was going to try a new sensor cause my uncle has the same car and he has a new 02 sensor and said i could use it to check it.its a oem plug sensor so im not going to rig anything up.i already replaced the wire harness that goes to the 02 sensor and tried a new ecu and it still comes up.
The Neutron
Jan 10, 2015 09:44 PM
icedemon
Apr 19, 2006 02:09 PM
SpyderZEX
Jun 2, 2004 12:04 PM
screwthis
Apr 8, 2003 05:27 PM
