tial twin and hose set up
Old Apr 10, 2011 | 06:20 PM
edsperformance's Avatar
Default tial twin and hose set up
hi guys i need to know if this set up do the job or i need
to do one line for each one,this is my first set up with twin
gate,any advice im apreciate
Old Apr 10, 2011 | 06:26 PM
dturbocivic's Avatar
Default Re: tial twin and hose set up
seems like it would work, although, it also seems like the one gate with the "source" might be a bit more responsive than the other gate
Old Apr 10, 2011 | 06:41 PM
so you think is not the best way to go
Old Apr 10, 2011 | 07:16 PM
i would have to assume it would not be the "best" but im sure it would work
Old Apr 10, 2011 | 07:22 PM
nonvtecallmotor's Avatar
That will work.
Old Apr 10, 2011 | 07:39 PM
TDautowerkes's Avatar
They make a Pushlock "T" thats Female on all 3 sides.... cut blue and black lines and T into them.... block off the other 2 ports of course
Old Apr 10, 2011 | 07:42 PM
can some one put photo of personals set up
Old Apr 10, 2011 | 07:44 PM
Old Apr 10, 2011 | 07:56 PM
tepid1's Avatar
Like Dave said, if you "T" it the gates see the same instead of one being stronger than the other. I'd do it that way.
Old Apr 11, 2011 | 07:10 AM
TiAL's Avatar
T it and make sure all the lines are the exact same length
Old Apr 11, 2011 | 11:35 AM
extralargenog's Avatar
Meh. Pushlocks here. Mines into a T at the first gate, then into the next gate (both top and bottom ports)... 5" in between them... Works perfectly fine. Neither side is going to be "stronger" The pressure will equal out quicker than would matter....
Old Apr 11, 2011 | 04:46 PM
first of all,your mani is sick,i think the same because air needs go through
the lines to fill both gates before makes the presure on the lines,were are
you guys found push lock fitting mine are 6mm
Old Apr 11, 2011 | 04:58 PM
xenocron's Avatar
Air doesn't need to go through the lines...nothing is flowing here.
Like Rick said, what you gave will work just fine!
Old Apr 11, 2011 | 05:21 PM
i go in that way because i dont find the t anyware in puerto rico
so this is what i have,thanks for your time and support is a great
forum
Old Apr 14, 2011 | 01:37 PM
Fabian's Avatar
forum
trata inrumec estan en gurabo y tienen gran variedad de fittings,yo compre las mias alli.
Old Apr 14, 2011 | 01:48 PM
Garage 808 Hatch's Avatar
mine was the same as Spikers
Old Apr 14, 2011 | 01:57 PM
turbo-2nr's Avatar
so on the new mv-s tial there is 2air ports on top and 2 on the bottom plus the water colling ports ?
O and J Performance's Avatar
forum
Dame una llamada yo te las consigo aqui y te las envio pa la isla
Old Apr 14, 2011 | 04:57 PM
xsi-t's Avatar
AbitAvenger
Sep 27, 2006 04:39 AM
Killer_B
Dec 3, 2003 10:49 PM
