b20b build questions.
Old Apr 10, 2011 | 01:53 PM
Zombie1890's Avatar
Default b20b build questions.
so here it goes i have a 97 integra ls with a jdm b20b. Right now the only things done are dc sport headers, stock cat, custom 2.5in catback with 3in resonater, and ebay intake. its not much for now pretty much stuff i had laying around. i would like to build it all motor but non vtec. and was just wondering where a good place to start was. also it will be doing an obd1 conversion this week at some point. thanks
Old Apr 12, 2011 | 10:58 AM
Scorchin Civic's Avatar
Default Re: b20b build questions.
Let me ask you this, do you still have your LS transmission? If you do then I would look into at least getting a GS-R transmission. Why I say this is you would get better gearing for acceleration then the LS transmission. I had a B20 build and used a B16 transmission and loved it.
Old Apr 12, 2011 | 11:29 AM
Mr. EG's Avatar
I would start by bumping the compression up, selecting a cam, sourcing a B16/ITR trans and investing in a better header and a tune.
Old Apr 12, 2011 | 11:56 AM
unusual71's Avatar
tune, tranny, better header, better intake manifold, better cam, in that order. compression will make the least difference unless you plan on really raising it, to say past 11:1
actually a good, cheap upgrade is a b18b intake cam. noticeable difference as the b18b profile is more "sporty" and it has like .025" more lift or so
lastly arp rod bolts if you plan on spinning to 7k or further. i went 7.5k on stock bottom end + rod bolts and had zero issues just changed them 1 at a time without bumping the rod caps.
gunsnbam
Feb 29, 2012 09:45 PM
BearsEK-KMSU
116
Dec 27, 2009 08:05 AM
dohcnotec
10
Sep 27, 2009 07:02 PM
rEnZ94tEgGy
Jul 27, 2009 10:52 AM
crazydominicanman
Feb 15, 2009 12:11 AM
