Zip tie valve spring compressor. It Works!
Old Apr 9, 2011 | 08:07 PM
gorillahumper's Avatar
Icon3 Zip tie valve spring compressor. It Works!
I was putting together a d16 head without a spring compressor and this is what i came up with. Sure the right tool would work better, but you don't get better than this for free! Tell me what you think, try it out. It may seem annoying at first but becomes easy quickly.
Here's the link to a video i made
http://www.youtube.com/watch?v=_qqtk...layer_embedded
Questions?
Old Apr 9, 2011 | 09:07 PM
Blaze45's Avatar
Brrraaaap!
Default Re: Zip tie valve spring compressor. It Works!
This is great if you have no money!
Old Apr 10, 2011 | 11:20 AM
I guess someone has to state the most obvious thing.
Old Apr 10, 2011 | 11:29 AM
mouab18c1's Avatar
Ghetto!
Old Apr 10, 2011 | 01:40 PM
logic factory's Avatar
not letting your resources dictate limitations; objective people should see inspiration in this rather than misplaced critique. i can admire the ingenuity.
thank you for sharing and find comfort in the notion that if you continue to find solutions to your problems you will eventually, if you have not already, transcend greatness.
Old Apr 10, 2011 | 06:29 PM
Thank you. Someone with some common sense
Old Apr 12, 2011 | 01:47 PM
96GeeSR's Avatar
do you know if this'll work on a b18c1?
Old Apr 12, 2011 | 02:50 PM
mik101's Avatar
Might be a problem if there are dual valvesprings in it. I can't remember what's oem in a C1 head anymore. Obviously a type-r head would have duals on both sides. It may work if you zip tie the outer spring if the inners can be compressed while putting on the retainer. Hmm.
I have the machined aluminum compressor specifically for these heads. I forget who is making them now. Really worth it if you do this more often than once a year.
Old Apr 12, 2011 | 04:34 PM
dem0nk1d's Avatar
i call it fuzzy logic! bad ***. getting things done with limited resources.
Old Apr 12, 2011 | 05:10 PM
It should work on anything with a light enough spring. Dual valve springs create another problem, I think the zip tie's would break as i happened a couple of times to me. As far as doing the inner and outer seperatly you wouldnt be able to get the zip tie out. The proper spring compressor is the best solution but i wanted to put this up and maybe it would get someone out of a bind. Thanks for the props!
Old Apr 12, 2011 | 07:04 PM
dem0nk1d's Avatar
You sir are a ziptie master. There are only a few of on this earth, and you are one of them.
I once used a ziptie to fix a busted gas peddle on a uhaul truck, it got me to where i needed. PROPZ
Old Apr 13, 2011 | 06:54 AM
wc4ohio's Avatar
I like the idea. Still, compressor tools are cheap as a ****. Either way, +1 for a last second redneck engineered tool (not to use "redneck" in an insulting way; I believe redneck engineering is a popular term for homemade tools and fixes, and some people take it as a compliment)
Old Apr 13, 2011 | 05:20 PM
No worries.
Old Apr 18, 2011 | 11:03 AM
96GeeSR's Avatar
So i just replaced my valve stem seals in my B18C1 and i used the zip ties to compress my valve springs and it does work.
Old Apr 18, 2011 | 06:26 PM
Nice. FTW
Old Apr 18, 2011 | 06:35 PM
ken9's Avatar
Look goodie but kinda hard to see how putting the tied.. I will try it when i go broke..
Old Apr 18, 2011 | 07:18 PM
Atomic1's Avatar
Props for the zip tie idea.
I know it's a lot of money, but I would drop the $1.99 for a set of safety goggles. Anytime you work with springs it's a good idea.
Old Apr 19, 2011 | 05:44 AM
thenext's Avatar
20% cooler
Zip ties FTW!
Old Apr 20, 2011 | 08:49 AM
siregcivic's Avatar
i switched a bent exhaust valve out on a obd0 b16 head without a comperssor... i had a towell on my table and i had a rag and the head was on top of the rag where the cylinder was that i had to replace the valve...
i had a friend with the keepers in his hand and i pushed the valvespring down far enough with my thumbs that he could pop the keepers in...
not kidding those obd0 vtec heads exhaust single valve springs are weak... this was a b16 head
Old Apr 21, 2011 | 04:39 AM
thenext's Avatar
20% cooler
Man! I'd like to see that be done on GM vortec engine, the spings on those might as well be a solid hunk of metal.
Old Sep 25, 2013 | 01:10 PM
0c00l's Avatar
Sweet idea, Macgyver lives on!
Old Oct 13, 2021 | 03:46 PM
Uuuuggghhjerry's Avatar
[QUOTE=gorillahumper;45043690]I was putting together a d16 head without a spring compressor and this is what i came up with. Sure the right tool would work better, but you don't get better than this for free! Tell me what you think, try it out. It may seem annoying at first but becomes easy quickly.
e
Okay I got to ask so how do you guys get this part of the zip ties on the inside of the spring back out
Old Dec 2, 2021 | 06:04 PM
chidog's Avatar
Reminds my of some of my zip tie capers, my last one was compressing the spring in a CVT variator.
Timo2
Feb 14, 2014 08:54 AM
RacinMasonC
May 10, 2008 09:48 AM
averyvm
23
Feb 27, 2007 06:54 PM
97eksoldier
Oct 25, 2006 12:27 PM
