Question about my Build!Civic Si 99..new member!
Old Apr 9, 2011 | 05:59 PM
vtecfr34k's Avatar
Icon2 Question about my Build!Civic Si 99..new member!
Hey guys i'm new here, i just wanted to know what should i change to increase HP and torque (except turbo)
My Build..Civic Si 99:
B16a SiR DOHC vTEC
Type R Transmission
Blox B Camshafts
Wallbro gas reg
AEM Intake
Skunk2 Intake Manifold
Aluminum Racing Radiator ROW 42MM
Cam gear Skunk2
Skunk2 Titanium retainers
P70 ECU
AEM Conical Air Filter
Oil Catch Can
Bronze Clutch 4f
Fullcoilovers Skunk2
Headers DC Sports
What's else can i get or what should i do for improve hp ?
Thanks
Old Apr 9, 2011 | 06:35 PM
hoffmanb16's Avatar
Default Re: Question about my Build!Civic Si 99..new member!
swap that block out for a b20 or turbo.... b16 all motor builds are VERY limited.
Old Apr 9, 2011 | 06:39 PM
negusjuda's Avatar
i have a built b20 block for sale if your interested
http://www.hondamarketplace.com/showthread.php?t=292135
Old Apr 9, 2011 | 06:44 PM
UncleD's Avatar
https://honda-tech.com/search.php
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/official-all-motor-dyno-thread-1583606/
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/b16a2-all-motor-2916035/
Old Apr 9, 2011 | 06:55 PM
ghost914's Avatar
your stock b16 tranny is good enough i would invest in a LSD RMF header or a custom set and a programmable ecu like crome or hondata etc and if your looking for power swap out the block
Old Apr 9, 2011 | 07:28 PM
Libertariat's Avatar
Ek Forever y0!
Thanks
Sell all of your junk parts and buy a QSD kit and an h22 long block.
Old Apr 10, 2011 | 12:58 AM
N/A's Avatar
N/A
Purpose Built
Why would he switch back to a b16 trans?? He already has better gearing and lsd
I can quote a few members talking about the TODA header dominating others on the b16..
OP, do you have a specific hp you would like to reach?
Old Apr 10, 2011 | 10:17 AM
vtecfr34k's Avatar
Yes, 250hp
Old Apr 10, 2011 | 10:26 AM
93egSLEEPER's Avatar
Yes, 250hp
Turbo or Nitrous. Period.
Old Apr 10, 2011 | 10:28 AM
2k.civic.si's Avatar
dont waste your time with the b16....i own a 2000 civic si and after dumping a lot of money into the b16 i still wasnt happy. you should either boost the b16 or build a b18 bottom end with some decent compression or go for a b20 bottom end and build that.
my current build is a very high compression b18c bottom with ported polished b16 head and all the supporting mods. if you saw all the receipts for how much money i have into this you would puke. just an fyi....im still not happy and im making about 220whp.
if i had to do it all over again....i would have built the b16 bottom end and boosted it 16-18psi on a gt30 or something similar.
Old Apr 11, 2011 | 08:12 AM
cibao2ner's Avatar
b166 love nitrous...nitrous adds alot of torque which they lack...and you can spin them high...if u do it right it will be fun...
Old Apr 11, 2011 | 08:21 AM
Ek Forever y0!
What's a b166?
And why does a b16 in particular perform better with nitrous than say a b18c1? b18c5? b18b? h22?
Spin what high? The engine?
B16's red line at 8,000rpm
b18c1 red lines at 8100rpm
b18c5 red lines at 8600.
Higher red line doesn't necessarily mean more power. That's a formula calculated using the stroke. h22's make a lot more power all across the power band and red line at ~7500rpm.
Old Apr 11, 2011 | 11:44 AM
Mr. EG's Avatar
Ditch the B16 block, find a 1.8L- 2.0L block and then build that. If you think you can touch 250whp or even 250 hp at the crank with a B16 block you should probably lay off the pipeski.
turboef90
Northeast (Sales)
Jan 13, 2014 02:52 PM
vtecfr34k
Apr 14, 2011 04:18 PM
Rav
Feb 10, 2008 12:18 PM
sleepycivix
Feb 7, 2003 11:24 PM
