Locating the Bleed Nut
Hey guys i just bought a 94 del sol dohc vtec. These past few days the clutch has gotten really soft( no pressure from clutch).I went to the shop to ask how much it was going to cost the guy quoted me 70 dollars. I saw how simple this process is on youtube only they werent doing the guide on my specific car. So i refuse to pay that mechanic that much when i can probally do this in less that 20 minutes with some help from others. First I checked the fluid in the resevior and to my surprise it was filled. My next thought is to bleed the slave or master cylinder. But where is the nut i am suppose to loose before pumping the clutch??? I cant find it. Is it on the bottom of the car or is it near the master cylinder?? I see 2 hoses that come out of the master but how am i suppose to loosen that thing.... Thanks for all the help in advance!
bleeding takes 2 persons unless you buy a bleeder kit. one person pumps clutch 10 times, hold it on the last one and you loosen the bolt till it squirts out and close it. pump 10 more times and repeat the process till it squirts out just liquid. I put a disposable cup and filled it with the brake fluid till the valve was covered so it wouldnt suck in any air. after about 4 attempts it stopped squirting air.
707EF8
Jul 29, 2006 08:32 PM
hybridgs
Aug 26, 2005 06:39 AM
AndyD
Feb 3, 2003 09:47 AM
