Walboro 255 - bad fuel pump-b16
Old Apr 9, 2011 | 12:53 PM
phelpsj2's Avatar
Default Walboro 255 - bad fuel pump-b16
hey guys i think my fuel pump is about to take a ****. every often atleast once a day or everyother day, my car will just shut off randomly. also it will cut out for a split second everyonce in a while. one time the car would not start back up after cranking and cranking but it usually will start right back up and be fine. i have no check engine lights except the p0141 for 2nd 02 sensor which ive had since ive had the car, and p1457. if i get a walboro 255 ( im boosting the within a year) will it be fine to just swap in, or will i need an adjustable fuel pressure regulator also to compensate all that extra pumping.
Old Apr 10, 2011 | 05:10 AM
Red_Army's Avatar
Default Re: Walboro 255 - bad fuel pump-b16
you'll be fine. it'll be a lil overkill til you boost it but its better then buying something twice.
JmurGSR98
May 20, 2012 05:26 PM
preludepimpin8668
Sep 4, 2007 01:38 PM
90TegraB18C
Aug 27, 2006 05:32 PM
sol2nr
11
Jun 23, 2004 06:36 PM
EK9Blitz
Mar 27, 2004 08:49 AM
