brake questions from non abs to abs
swapping everything from a da with no abs to one with abs. the shell with abs is the new one we will be using but we dont want or will need the abs. if we were to remove the abs pump etc what is everything ill need to change and do to run the brake system the same way as the one with no abs? new brake booster? from what model if so? brake lines? etc for the front and back brakes any info will be apreciated thx
