Want to Buy Want to Trade/Want to Buy
Want to Buy D15B 3 stage block or Crank & Rods
Old Apr 9, 2011 | 09:01 AM
labomedia's Avatar
Default Want to Buy D15B 3 stage block or Crank & Rods
I have a 97 ek3 sedan ferio with 3 stage d15b that spun a bearing. I want to buy the complete 3 stage block or the crankshaft and connecting rods.
I'm located in the Islands but I have a shipping forwarder in Miami.
PayPal Ready.
Old Apr 9, 2011 | 09:32 AM
qweakers's Avatar
Default Re: Want to Buy D15B 3 stage block or Crank & Rods
if i remember correctly the 3stage d15 uses the same size crank has the regular d15, only d15 that was different was the single stage vtec d15b with the 1.6 rod journals
Old Apr 9, 2011 | 09:49 AM
labomedia's Avatar
Thanks for clearing this up.
D15 crankshaft & Rods anyone ?
Old Apr 9, 2011 | 02:33 PM
labomedia's Avatar
Old Apr 9, 2011 | 03:36 PM
qweakers's Avatar
i have some, but you may want to verify that i am 100% correct before you purchase from anyone, including me. would hate to send you something on what i believed to be true and it comes out false
Old Apr 9, 2011 | 03:58 PM
labomedia's Avatar
I feel ya..especially when my customs charges 69% of CIF.
My Mains Are 45mm
My Rods Are 45mm
Old Apr 9, 2011 | 04:04 PM
qweakers's Avatar
got pics of the rods themselves or what is the stamping on them
Old Apr 9, 2011 | 04:14 PM
qweakers's Avatar
just looked up some specs in one of the service manuals
you have the elusive crank
a regular d15 would be 45 on the mains and 42 on the rods
you could use a regular d15 crank, pistons, and rods. if you wanted to change all that out
Old Apr 9, 2011 | 04:17 PM
labomedia's Avatar
The motor is still in the car i just pulled the bottom pan. The stamping on the rods caps are m3 .4 and on the side of the rod 07.
Old Apr 9, 2011 | 04:31 PM
labomedia's Avatar
do you know what else will change? oil pump? C/R? Performance?
Old Apr 9, 2011 | 08:26 PM
qweakers's Avatar
it depends on the length of the rod which should be 1.6 rod length and specs of the pistons that are in the motor right now. oil pump wont have to be changed, bearings should or at least checked.
depending on the length of the rods it can go one of two ways you could use vx rods with a stock regular d15 crank, or swap the pistons and rods out and potential gain a full point of compression
amadriga
Apr 22, 2016 07:18 PM
lunatics209
Jun 12, 2008 01:38 AM
Ding
Oct 31, 2005 03:03 PM
turbotypeR@SPEC
Dec 5, 2004 10:51 AM
dc2dragster
Apr 15, 2003 09:36 PM
