My 88 Civic Sedan(Could use help/opinions
ok so i started a wire tuck Im half way done just gotta do the passenger side & ill be done.
On my journey of doing this wire tuck I am gonna do a mpfi swap with a z6 intake mani.
I have a question about this item on the fire wall( I was toldits my map & evap) & im posting 2 pics of the driver side tuck if anybody wants to add anything be my guest but please remember this is my first wire tuck ever
I have the evap on the back of my z6 intake but i dont have a map sensor on the b18 ls tb?
yes the bracket has your evap purge solenoid valve and the map sensor if you wan to get rid of the bracket get a obd1 tb with the map sensor on it and hidde your purge solenoid if not just pug the mani and dont run your evap at all
also again your evap is emission control so its your choice
ok jw but i think imma use the evap on the intake & imma try to telocate that bracket lower on the firewall so its outta the way & nobody will see it
CRXguy_88
Jul 11, 2010 09:10 PM
