My Friends car is stuck on the side of the road!
Old Apr 8, 2011 | 12:26 PM
Pancho2193's Avatar
Default My Friends car is stuck on the side of the road!
So he was driving down the street and his civic's RPM's just started falling and bogging, and it turned off. Its an EK with a D16...any troubleshooting tips?
Old Apr 8, 2011 | 12:27 PM
rick_rabies's Avatar
I'm not Rick!
Default Re: My Friends car is stuck on the side of the road!
any more info?
Old Apr 8, 2011 | 12:28 PM
I'm not Rick!
run out of oil?
ground fall off?/battery cable come loose
gas in the tank?
check ecu fuse?
overheat?
main relay good? you wouldnt be able to tell on the side of the road though.
plug wires come loose?
Old Apr 8, 2011 | 12:29 PM
Pancho2193's Avatar
He has Oil, half tank of gas....which one is the ECU fuse? Not an overheat (Or atleast I think, since there was no smoke)
Old Apr 8, 2011 | 12:30 PM
I'm not Rick!
should be in the box under the hood. its a 15amp
if thats blown it acts the same as if the main relay is out.
does he have power?
Old Apr 8, 2011 | 12:32 PM
Pancho2193's Avatar
Car turns over but no start.
Old Apr 8, 2011 | 12:47 PM
I'm not Rick!
does it sound normal when hes trying to start it?
blow a head gasket?
suck up water in the intake?
Old Apr 8, 2011 | 12:56 PM
grumblemarc's Avatar
The Grumpiest
CELs?
Old Apr 8, 2011 | 01:25 PM
hyperblu's Avatar
timing belt
Old Apr 8, 2011 | 01:36 PM
ReDHaTcHyGuy's Avatar
alternator went bad?
Old Apr 8, 2011 | 01:37 PM
raidacaipo's Avatar
Originally Posted by hyperblu
timing belt
x2! Check this.. Open up the oil cap and look towards the timing belt. See if you can see it wrapped around the cam pulley or not
Old Apr 8, 2011 | 03:00 PM
accrdwgnguy's Avatar
There is no way you are going to see the t/b thru the oil cap.
Has your friend ever changed his spark plugs?
Old Apr 8, 2011 | 03:11 PM
sk8shorty012's Avatar
You need air, fuel and spark to start a car. Air is pretty self-explanatory. Check for fuel and spark.
Old Apr 8, 2011 | 03:17 PM
raidacaipo's Avatar
hey its worth a try if your stuck somewhere wit no tools to remove the cover lol..
Old Apr 8, 2011 | 07:24 PM
300whpej's Avatar
check the rotor button. also, dont try and look for the timing belt through the oil cap opening; you will just look silly.
Old Apr 8, 2011 | 07:41 PM
civicsmoke's Avatar
thats why you look to see if the cam is spinning, if its not timing belt snapped. youd definitly not be able to see the timing belt from the oil cap thow lol
Old Apr 8, 2011 | 07:43 PM
Frozen E's Avatar
H-T White Ops
What he means is that there's absolutely ZERO way to see the timing belt through the oil filler hole. If you can see your timing belt through your oil filler hole, I, as well as the rest of H-T) want pics.
It's kind of like checking your air filter through your wheel's valve stem.
Old Apr 8, 2011 | 07:44 PM
civicsmoke's Avatar
that wouldnt shut the car off like that, your battery light would come on first.
Old Apr 8, 2011 | 08:26 PM
Linked's Avatar
blowing that 15A fuse would shut it off immediately, it wouldnt bog down,
a snapped t/b would shut it off immediately
running out of gas would make it sputter
probably sucking in water but if he doesnt have an CAI
i'd say check your typical fuels and sparks
Old Apr 8, 2011 | 09:22 PM
raidacaipo's Avatar
Thanks for rubbing it in.. Do you feel better now?
Old Apr 8, 2011 | 09:29 PM
Frozen E's Avatar
H-T White Ops
Not before. Now I do though. :D
Old Apr 9, 2011 | 04:36 AM
delsolintegra's Avatar
Shoot starting fluid in the throttle body. If the engine fires then you have a fuel problem.
When you turn the ignition key to first position do you hear the fuel pump whirrr to charge the fuel rail? If not it could be the fuel pump. Also change the fuel filter.
Old Apr 9, 2011 | 04:39 AM
hondaon18's's Avatar
Maybe your dizzy went bad that always seems to shut the car off and not turb on but just crank and crank till the battery dies .
Old Apr 9, 2011 | 11:34 PM
redlinexd's Avatar
could be main relay, i remember my friend's G1 integra kept bogging down when slowing down at a stop sign or redlight and it was a bitch to start it up.
Old Apr 10, 2011 | 12:23 AM
Solster's Avatar
if your using starting fluid on your car for any reason your better off calling a wreaking yard to scrap it out.
starting fluid is as good for your motor as reving it to 4K RPM and sticking a garden hose in the intake. come to think of it that might do less damage.
any way if you want to see if it a fuel problem use CARB cleaner it's cheaper and you wont risk cracking a piston.
