Speedometer and Odometer don't work, everything else does. Fixable? 1991 DA
Just bought a 1991 DA that needs a lot of work, its basically just a learning project for me.
I noticed the Speedometer and the Odometer don't work, but everything else does. Is it possible that the previous owner just unhooked them to prevent miles adding up? Is that pretty common to do? Would it be hard to hook them back up? Any help would be awesome, thanks!
your speedo cable is broken, most likely due to excessive force upon removal of the cluster at one point in time. this is very common
yea you can order the replacement cable from honda.
Here is the link to order
https://www.acuraoemparts.com/delray...All&vinsrch=no
Here is info on how to replace it. It doesnt have the pictures anymore but it will get you going
http://forums.g2ic.com/showthread.ph...t=speedo+cable
