Who knows ECU's and TCU's *transmisson control units*
ok i have a 96 lude in my h22 and auto jdm h22 tranny. it shift at accord rpm's cause of the accord tcu. will a 97 lude tcu work ok. i know the ecu has an immobilzer but the tcu plugs to tranny will it work out ok? cause its almost impossible to find a 96 tcu
Thats a good question. My TCU is my right arm, but You might try a book like a Haynes manual. They cover pretty well alot of things. Also might try contacting a dealer for the schematics for the TCU and cable pinouts. Never messed with one but I would def be lookin for schematics to know what wire goes where.
Just some thoughts.
Just some thoughts.
thanks thats a path i can take into consideration. thanks again.. anyone else know bout the TCU? will it being a 97 effect anything or are they the same, and just the ecu's changed.
the 97-01 tcu auto trannys have the sport shift so it would not work for the 93-96 96 is obdII but still uses the non SS trannys. try using the 2.3 auto TCM (TCU). BTW what happened to the lude ECU why are you using the accord's.
KTeller8
Feb 14, 2003 04:22 PM
