inline fuel pump
Old Apr 8, 2011 | 03:37 AM
pleej's Avatar
Default inline fuel pump
ive bought a inline fuel pump to run off a fuel cell , can i just wire the green and yellow + wire to the live on the pump and the black wire to the neg on the pump.
i did some reading but i think ive got confusted when people started to use relays and stuff.
thanks
Old Apr 8, 2011 | 06:12 AM
fcm's Avatar
fcm
Old Fart
Default Re: inline fuel pump
It depends on the current draw of the inline fuel pump, how much power does it need?
The stock fuel pump power lead is good to 20A if your inline needs mor current you will need to use a relay and a run a power lead, a fuse 14-12 gauge lead from the batt, to close to inline pump and connect to #30 of relay, connect #87 of relay to fuel pump pos.(+) using same gauge wire as you ran from the batt., connect the srock fuel pump power lead, [green/yellow] to #85 of relay, connect #86 of relay and the inline fuel pump ground to chassis ground.
Feel free to IM me if you have questions.
Read... http://www.the12volt.com/relays/relays.asp 94
Old Apr 8, 2011 | 08:04 AM
pleej's Avatar
thanks for the reply, only thing is i dont know if its a 20 or 30 amp pump lol i bought it from a friend , ive had a look and cant see any were it says what amp's it is, is there any way of telling.
Old Apr 8, 2011 | 09:43 AM
wc4ohio's Avatar
You could probably hook the pump up to a battery and use an analog ammeter inline with the circuit you make. I wouldn't use a digital meter. It's not a good idea to run a fuel pump dry either.
Old Apr 8, 2011 | 11:06 AM
fcm's Avatar
fcm
Old Fart
Then to be safe, run the power lead and use the relay. 94
d_boi_swag
May 4, 2013 07:01 PM
hondaluver12
Jan 30, 2012 02:37 PM
zippakilla
Feb 6, 2009 04:01 AM
Jamison
Jul 11, 2002 12:07 PM
DOHCarp
Apr 1, 2002 04:40 PM
