got a 97 accord for free but not starting,help
Old Apr 6, 2011 | 09:36 PM
westcoasthonda's Avatar
Default got a 97 accord for free but not starting,help
car was sitting for like 2 months and the battery died i dont know what the previous problem was to make the car sit my friend never told me,but i got the the battery charged at autozone and now the dash lights turn on and radio works but when i try to start it theres nothing the lights get dim on the dash,i can hear something engaging in position 2 but it doesnt want to crank,and when i put the battery in the alarm stays on could it be the aftermarket alarm not making it start?
Old Apr 6, 2011 | 09:40 PM
75aces's Avatar
Default Re: got a 97 accord for free but not starting,help
is the alarm a karr alarm?
Old Apr 6, 2011 | 10:12 PM
mavvrik's Avatar
If you got it from a friend you should probably start with asking him what the problem was
Old Apr 6, 2011 | 11:02 PM
its a xpos alarm i think it had the self start,i did but he has no knowledge when it comes to cars,also the gear screen on the dash has a green light around the d4 i was searching on other sites and it said something with a ecu problem?
Old Apr 7, 2011 | 09:05 AM
StreetsideStig's Avatar
I would start with the alarm.
The engaging sound you hear when turning the key is probably the fuel pump priming the lines. I'm not sure if that will still work when the ECU isn't, but that's something to look into.
Old Apr 7, 2011 | 09:10 AM
booted_wishes09's Avatar
im having a problem something like that with my 94 accord. try to jump it off with jumper cables
Old Apr 7, 2011 | 11:32 AM
alright thnx
Old Apr 12, 2011 | 05:18 PM
75aces's Avatar
were you able to figure out the alarm? did the d4 light clear?
Old Apr 12, 2011 | 05:21 PM
singlecamsaint's Avatar
check all the fuses and all grounds
Old Apr 12, 2011 | 05:58 PM
gqstatus05's Avatar
Main relay
Old Apr 12, 2011 | 06:16 PM
gogydm's Avatar
Could be main relay, or some sort of ecu issue. Check what code the blinking light is telling you.
Old Apr 13, 2011 | 09:30 PM
sleeps41's Avatar
I had a similar problem once. When it would refuse to start, I would get a jump. Then ended up replacing the starter. When the problem persisted, i removed the old alarm in it. But it came back only to find that the problem was a bad ignition switch. Hope this helps.
monkeytoes
Apr 23, 2017 07:52 AM
Midgetmax4
Mar 31, 2007 06:27 AM
asujzgirl
Audio / Security / Video
Jan 12, 2006 11:19 PM
Airbag Club
21
Feb 2, 2004 02:05 PM
