teg calipers on cx civic knuckles?
Old Apr 6, 2011 | 04:23 PM
boarding2008's Avatar
Default teg calipers on cx civic knuckles?
first how much bigger are the front brakes on a LS/GSR (DC4/2) than a 92 cx? and is it possible to just buy integra calipers, pads and rotors and bolt them on?
Old Apr 6, 2011 | 04:32 PM
94EG8's Avatar
Seagull Management
Default Re: teg calipers on cx civic knuckles?
Rotors are about an inch bigger, caliper piston is a lot bigger. They make a huge difference, far more worthwhile that doing a rear disc swap.
No, you need the knuckles and flex lines from an Integra or '92 - '95 Civic EX. You also need a '94 - '97 Integra RS brake booster and master cylinder (or alternatively a '90 - '91 Civic EX master cylinder) prop valve should also be changed to a '90 - '97 Integra unit from a non ABS car.
Old Apr 6, 2011 | 05:13 PM
i currently have a 40/40 prop valve. i believe my booster &master are from my old LS with ABS. obviously my cx doesnt have abs so im guessing i need to get new ones?
Old Apr 7, 2011 | 12:21 PM
I already have rear disks on my civic from my old LS that i scrapped a while back. so do i need a NON-ABS booster and master? like i said in my post before i already have a 40/40 non abs prop valve.
Old Apr 7, 2011 | 01:21 PM
94EG8's Avatar
Seagull Management
If you already swapped the LS ABS MC on then no, it just requires bending and flaring lines when the non ABS version just bolts right up.
Old Apr 8, 2011 | 05:57 AM
ah alright. im going to start looking for some teg front knuckles then lol. thanks a lot.
Old Apr 28, 2012 | 11:08 AM
gaskethead's Avatar
Will the Integra RS brake booster/master cylinder combo bolt directly on eg?
Old Aug 27, 2012 | 05:11 AM
Mr. EG's Avatar
yes^
VTEC-in_Beaver
Feb 10, 2008 07:15 AM
NinetyTwoHB
10
Feb 12, 2005 11:31 PM
AThiker
Nov 23, 2004 10:02 AM
lonefuzzy79
Apr 23, 2002 09:25 AM
Yellow Dragon
Apr 16, 2002 10:19 AM
