d16z6 timing belt, water pump, tensioner and seals replacement recommendation
Old Apr 6, 2011 | 03:58 PM
born2lose's Avatar
Default d16z6 timing belt, water pump, tensioner and seals replacement recommendation
here are all the parts im replacing but i was also told to replace the cam seal and crank seal but i can not find the part number for either one. i was also wondering what else should i replace since im in that area. i do plan on keeping it for many more years and it has 165k miles.
14400-P28-004 012 001 BELT, TIMING (104RU24 A-555) (UNITTA)
14520-P2A-305 013 001 TENSIONER SET, TIMING BELT (KOYO SEIKO)
11831-P08-000 004 001 RUBBER, SEAL (LOWER)
11832-P28-A00 005 001 RUBBER, R. BACK SEAL
11833-P08-000 006 001 RUBBER, L. BACK SEAL
i want to replace #20 which im sure it is the cam seal but there is no part number and i do not know where to find the crank seal, unless the lower rubber seal is it?
http://www.hondaautomotiveparts.com/...+-+TIMING+BELT
19200-P08-004 001 001 WATER PUMP (YAMADA)
19222-P08-004 002 001 O-RING, WATER PUMP (YAMADA)
19301-P08-316 003 001 THERMOSTAT ASSY. (NIPPON THERMOSTAT)
19305-PT0-000 004 001 RUBBER, THERMOSTAT MOUNTING
http://www.hondaautomotiveparts.com/...P+-+THERMOSTAT
all comments are welcome, just do not be an *** and tell me to search because i already have. thanks!
Old Apr 6, 2011 | 04:08 PM
94EG8's Avatar
Seagull Management
Default Re: d16z6 timing belt, water pump, tensioner and seals replacement recommendation
Cam seal: 91213-P2F-A01 OIL SEAL (29X45X8) (ARAI)
Crank seal: 91212-P2F-A01 OIL SEAL (31X46X7)
I had to get the cam seal part no. from BK Honda, not sure why it wasn't listed on hondaautomotiveparts Crank seal is under oil pump btw. Also the water pump gasket/o-ring comes with the new pump, same goes for the thermostat grommet/seal.
Old Apr 6, 2011 | 04:57 PM
born2lose's Avatar
i found the same cam seal part number for a d16y8 but i was not sure if it also fit the d16z6 but according from your info, i guess they do?
i did browse through the oil pump section but did not know that was the oil seal for the crank but i do now.
so youre saying my list shows extra o-ring for the water pump when it is included and extra rubber for the thermostat when it is also included?
Old Apr 6, 2011 | 05:07 PM
94EG8's Avatar
Seagull Management
If the number is the same then yes, it's probably the same for several other D-series cams actually.
Correct.
Old Apr 7, 2011 | 12:47 PM
born2lose's Avatar
does anyone recommend anything else more or less before i order the parts?
Old Apr 7, 2011 | 01:28 PM
94EG8's Avatar
Seagull Management
I really can't think of anything else I could recommend. Other than a tube of Hondabond for the corners of the valve cover gasket, and maybe a new valve cover gasket if yours is leaking.
Old Apr 8, 2011 | 08:43 PM
born2lose's Avatar
ok, parts are here.
Old Apr 24, 2011 | 10:28 AM
born2lose's Avatar
so my mechanic said the following parts are extra and should not be replaced because they do nothing to the engine and are just seals for the timing belt cover, not the motor
what do you guys think?
autodriver
Honda CR-V & Element
Jun 4, 2012 04:49 PM
frokido
15
Jan 23, 2011 06:31 PM
The-Kid
Feb 8, 2008 03:47 PM
vinuneuro
Aug 9, 2005 12:48 PM
blue32
Jun 1, 2005 02:10 PM
