Need help b18c1 to d16y8
Old Apr 6, 2011 | 03:51 PM
turbod16y8's Avatar
Default Need help b18c1 to d16y8
Hey guys i have a dilemma here. I recently bought a 1996 civic ex with a 1998 gsr b18c motor. motor was running but had a rod knock so i swapped out the GSR motor for a d16y7 with y8 head. Heres the problem. The d16y7/y8 would idle on the P72-013 (gsr ecu) but would choke out if i gas it. The motor is running too rich. When i swap the ecu with a p2e-a01 (d16y7 ecu) It doesnt start at all. Ive checked all the wiring. What could it be?
Old Apr 6, 2011 | 04:13 PM
raidacaipo's Avatar
Default Re: Need help b18c1 to d16y8
I dont think you can run a y7 ecu on a vtec motor. The iacv wiring is all different. You will have to convert that back to the configurations of a non vtec motor. I would suggest buying a obd1 p28 ecu with a conversion harness and running that.. I went from a h2b motor to a d16y8 and Im using a stock obd1 p28 ecu. Its runs great wit no check engine lights or emissions to think about for right now
Old Apr 6, 2011 | 04:16 PM
raidacaipo's Avatar
http://www.phearable.net/tech/wiring/wiring.96-98_2.jpg
Old Apr 6, 2011 | 04:17 PM
turbod16y8's Avatar
thanks just the answer i was looking for. So If i get the p2p ecu which is the OBD2a d16y8 ecu then it should start? I didnt know there was a difference between vtec and non vtec ecu except the vtec part of course...
Old Apr 6, 2011 | 04:18 PM
raidacaipo's Avatar
Yes it will start!
Wait read the IACV FIX EXPLAINED part on the website: http://www.phearable.net/tech/wiring/wiring.96-98_2.jpg
Also check your battery to see if its drained or anything.. does it even crank?
*I know that non vtec ecus for B series motors can be used on a vtec B motor but I'm not sure if its the same for single cams.
Old Apr 6, 2011 | 04:28 PM
turbod16y8's Avatar
yes motor cranks. I can start it with the p72 ecu but not with the non vtec p2e ecu.
Old Apr 6, 2011 | 04:30 PM
raidacaipo's Avatar
You should try it then. If not by this week I can borrow my friends y7 ecu and try it on my car to see if it works. But that might be 3 days later
Old Apr 6, 2011 | 04:36 PM
turbod16y8's Avatar
ok Ill look around for a p2p vtec ecu and let you know how it goes. thanks!
HondaPartsHero's Avatar
Technical Hero
You're going to have to figure out what to do with the intake air temp sensor and the CKF sensor is a different plug as well.
Old Apr 6, 2011 | 05:11 PM
turbod16y8's Avatar
all the plugs are plugged in right.
Old Apr 6, 2011 | 05:34 PM
turbod16y8's Avatar
Hey Raidacaipo Can you test out your friends ECU and see if it will start? i dont want to buy the ecu and find out that it wasnt it. Thanks In advance!
Old Apr 6, 2011 | 10:00 PM
raidacaipo's Avatar
Yeah Ill try and do it tomorrow if my friend comes over. If not tomorrow then on Friday
Old Apr 7, 2011 | 01:22 AM
Kista20's Avatar
if you run a p2p which is the for the y8 it's going to look for a knock sensor, also there is obd2a 96-98 and obd2b 99-00 so you'll need an obd2a ecu. Also make sure the rubber oil plug is removed on the y7 block because if you don't vtec will not work, Bauley's mini-me write up explains this.
Old Apr 7, 2011 | 02:40 PM
turbod16y8's Avatar
thanks! the knock snsor is already plugged in.
SovXietday
64
Jun 11, 2019 06:42 PM
Chrisjvargas
May 25, 2015 02:45 PM
snowuh
Jul 2, 2014 05:29 PM
wastedyouth2542
Dec 6, 2010 07:47 AM
vahonda97
12
Oct 13, 2006 06:53 PM
