Trailing Arm Bushing
Old Apr 6, 2011 | 12:46 PM
cyphon21's Avatar
Default Trailing Arm Bushing
Hey guys,
I searched but no answer was found.
My left rear trailing arm bushing is shot and giving me a nice clunk and rattle when driving and hitting bumps. I also believe it's causing some "floating" in the rear of the car too.
Anyways, I went to the Dealer and they don't sell the bushing seperate. Just the wole arm, for a nice $206CDN +taxes.
Anyone have any other suggestions or routes you went for this repair?
Any help is appreciated.
Edit: This is for a 1997 Acura 2.2CL
Thanks
Old Apr 6, 2011 | 09:42 PM
75aces's Avatar
Default Re: Trailing Arm Bushing
junkyard
Old Apr 7, 2011 | 12:51 AM
MAD_MIKE's Avatar
MM Gruppe B
Thanks
Could you order online and have it shipped?
http://www.acuraautomotiveparts.org/...s=&view=normal
Not sure which rear lower arm you need, but the most expensive is $125 US.
http://www.rockauto.com/catalog/x,ca...parttype,10401
Or Rock Auto?
Old Apr 7, 2011 | 04:35 AM
nus_dogg's Avatar
I'm sure they have it in stock. I bought my bushing separately when I had to replace a bushing that was shot on the passenger side rear lower control for the rear strut bolt.
Old Apr 7, 2011 | 11:58 AM
cyphon21's Avatar
Originally Posted by 75aces
junkyard
Need the bushing, chances are the bushing is worn out from a yard when removed.
Old Apr 7, 2011 | 11:59 AM
cyphon21's Avatar
Or Rock Auto?
I could order it and have it shipped. Seems like it will cost around the same after taxes, duty and all that jazz too
cyphon21's Avatar
Might be a Canadian Dealer thing?
If anyone can call their local Acura dealer and ask for it, it's the Driver's side rear lower trailing arm bushing I need.
Old Apr 7, 2011 | 12:01 PM
cyphon21's Avatar
The red circled part is the bushing location. I don't need the whole arm. JUST the bushing. No one lists that part seperate as far as I can tell
Old Apr 7, 2011 | 12:40 PM
kidcool1977's Avatar
SHAME ON YOU REBECCA!
Community Builder
I think suspension techniques makes a kit for the rear, you can go that route.
If not suck it up and buy the entire control arm.
Old Apr 7, 2011 | 12:50 PM
cyphon21's Avatar
@ RockAuto.com I came accross this art.... Part # 1014423
Can anyone confirm this is the right part?
Old Apr 7, 2011 | 01:36 PM
GhostAccord's Avatar
No sir! That looks to be a rear upper control arm bushing.
If you are in a tight spot financially. You could try removing the swing arm and drilling a few holes in the old bushing and then filling the holes and rest of the bushing opening with 3M window weld. Kind of like what the DIY guys do for engine mounts.
Old Apr 7, 2011 | 02:05 PM
cyphon21's Avatar
Yuck, that doesn't sound too fun haha.
I am in a crappy spot financially though. Ugh, I might just suck it up and replace the ONE side. Which I would rather not do.
Old Apr 7, 2011 | 04:35 PM
cyphon21's Avatar
Wil this work from a 1997 Accord EX?
RAYBESTOS Part # 5651218 Professional Grade; Trailing Link Bushing; 1 Bushing - Silentbloc
Rear ; Lower Inner
CAD$11.64
Old Apr 7, 2011 | 08:02 PM
I believe that part number is referring to the two smaller bushings at the other end of the trailing arm.
Old Apr 8, 2011 | 11:35 AM
cyphon21's Avatar
Looks like I am buying the whole arm haha..
I am going to make sure its the bushing actually gone, but i am %99 sure.
Old Apr 8, 2011 | 03:45 PM
slomofo's Avatar
GDD Member
That's a different bushing. The most common bushing failure on trailing arms is the bushing on the very front of the trailing arm. This bushing is located underneath the rear passenger seat area, not at the lower control arm. Trailing arm bushings aren't sold separately because they're installed at a precise angle that would throw the car's alignment off if installed incorrectly.
This is the bushing that usually goes bad:
Old Sep 4, 2014 | 01:21 PM
jkowtko's Avatar
I Just found Febest ... HAB-028 (front bushing) and HAB-101 (small rear bushings).
These are sold on Amazon and EBay.
http://www.febestpanamerica.com/About-Us.html
No idea on the quality -- of German origin and now HQed in Florida ... I would assume the manufacturing is outsourced.
But if the parts are as good as Moog (which I believe is also outsourced) then I would think it's worth a shot. For the price (14 + 9 + 9 = $32) compared with purchase of a complete OEM trailing arm (~$130) it definitely seems worth a try.
Old Sep 4, 2014 | 10:05 PM
MAD_MIKE's Avatar
MM Gruppe B
I would trust Amazon first.
Amazon.com: ARM BUSHING FOR LATERAL CONTROL ARM - Febest # HAB-028 - 1 Year Warranty: Automotive Amazon.com: ARM BUSHING FOR LATERAL CONTROL ARM - Febest # HAB-028 - 1 Year Warranty: Automotive
blaak-crx
Suspension & Brakes
10
Jun 2, 2008 05:14 PM
Reelizmpro
Feb 27, 2006 01:31 PM
mrtoastyjr
May 4, 2004 10:40 PM
Wes d
Jan 2, 2002 11:11 AM
