OBD0 to OBD1 Ecu harness question
Old Apr 6, 2011 | 08:00 AM
sirtimeless's Avatar
Default OBD0 to OBD1 Ecu harness question
So I picked up a rywire harness to do the dpfi to mpfi conversion.
Reading through the instructions, it assumes the car is already mpfi. It just tells me to cut out the resistor box. "SINCE" I am going from dpfi how do I wire up the injectors.
Currently I have 4 b7 injectors ( no resistor box) with extended cables. Do i need to wire them all together? If so then where do they connect.
The harness has 10 cables that go into engine bay, 2 of which are vtec and two for the ecu lights. Any help would be amazing.
Old Apr 6, 2011 | 08:08 AM
crx_si-r's Avatar
Default Re: OBD0 to OBD1 Ecu harness question
you should have done the dpfi to mpfi conversion first. i can build you a DPFi to OBD1 MPFi harness if you like. and also integrate the vtec components.
the extra sub harness coming off the ecu jumper will do you no good for the DPFI conversion. those are only for vtec, 4-wire o2, and a few others that you probably wont use.
zenon8890
Oct 13, 2009 04:00 PM
bobbyisking
Jul 7, 2008 09:22 AM
Fezzie
Aug 31, 2006 05:40 AM
88da3
Nov 13, 2003 01:12 PM
Norcalstoppy
Sep 20, 2003 05:45 PM
