Suspension & Brakes Theory, alignment, spring rates....
KYB AGX shocks, shopping for good springs.
Old Apr 5, 2011 | 07:19 PM
NAlover's Avatar
Default KYB AGX shocks, shopping for good springs.
I currently own a K swap Ej with;
KYB AGX's shocks (on some Megan 450lbs Front, 350lbs Rear spring rates coilovers)
Front and Rear full GSR suspenssion (brakes, sway bars)
drilled rotors and ceramic pads.
i'm seeking to get a quite stiff spring that will work great with the shocks i have now. I do not want to replace my shocks, i'm on a budget and the shocks are good.
i'm trying to set up the car for some road racing, auto X and over all great handling.
Whats are the best options on brands and springs rates available friendly with KYB AGX's?
thanks.
Old Apr 5, 2011 | 09:28 PM
PreyStayShun's Avatar
Default Re: KYB AGX shocks, shopping for good springs.
Hmmm....well you have all your typical H&R, Eibach, Tein etc... They're definately friendly w/your AGX's but I can't help but wonder whether those rates are too soft for auto x and/or road racing a k-series in an EJ.
I did a search for after market spring rates and found the following...don't know if this is much help but hopefully it'll start you out:
https://honda-tech.com/forums/suspension-brakes-54/cant-find-civic-oem-spring-rates-2891427/
GL Man!
Old Apr 5, 2011 | 09:34 PM
greenhatchyy's Avatar
ebay?????????????
Old Apr 5, 2011 | 09:43 PM
civexspeedy's Avatar
thanks.
You're not going to be able to go a whole lot stiffer with the AGXs. I believe the max you'd want to go on them is somewhere around 550lbs/in. However, the biggest upgrade while staying on the AGXs will be changing your rear spring rates. Going to say a 500 front/500 rear rates will balance the car out more and give you some oversteer.
As for springs, you can buy Eibach coilover springs directly from Ground-Control, they sell hundreds with different lengths, diameters and rates. I've heard good things about Swift springs aswell. Personally, I'd recommend the Eibach springs...
Old Apr 6, 2011 | 05:58 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I doubt the AGX's could take even a 400 lb/in spring for very long before going kaput.
Old Apr 6, 2011 | 07:43 AM
NAlover's Avatar
https://honda-tech.com/forums/showthread.php?t=2891427
GL Man!
Thanks man. It wont specially be a road race or auto x car to be honest, but i will enter a few events
during the year. I just want it to handle somewhat better since i drive the car often on the street.
Originally Posted by greenhatchyy
ebay????????????
I've tried but cant really find much information
Thanks man. I've heard good things about Swift springs too, but cant find info about them.
I just want the stiffest ride without changing my shocks now, eventually i will upgrade by the end of the year probably. K swap cars suffer fro
Oil pan ground clearance therefore a stiffer spring will help protect a little more. (got about 5-6 inches clerance)
.xcalibur.
Suspension & Brakes
Aug 19, 2007 03:49 PM
dip-set
Feb 10, 2003 05:18 AM
stoopid215
Sep 19, 2002 08:30 AM
Stage5Lude
Jul 1, 2001 09:57 AM
