95 civic ex. my plans need advise!!!!! Losing coolant
Old Apr 5, 2011 | 05:15 PM
ej1noob's Avatar
Default 95 civic ex. my plans need advise!!!!! Losing coolant
Ok hey guys I just picked up an clean 95 civic ex for. $900 come up..
Anyways. I noticed that I need to add water everyday. Uhm I'm 100%
Shure. The. Headgasket. Is. Out..
My. Plans. Are. To. Go turbo..
As. Of. Rite. Now the motor has 144k. Miles original
No leaks whatsoever. There is no white smoke nothing
Motor sounds healthy. Dosnt. Heat up on me..
Is it just a clean break on the Headgasket??
I'm not gna build the thing..
Can anyone tell me why no white. Smoke and no oil leaks or coolant leaks..
But burned out My coolant...
Thanx in advance...
Old Apr 5, 2011 | 06:45 PM
Wdpfreak145's Avatar
Default Re: 95 civic ex. my plans need advise!!!!!
Just because youre losing coolant doesnt mean its. The. Head. Gasket. (Cwutididthurr?)Any hose could be leaking. Check your oil for a milky residue on top. Thats a sure sign of bad head gasket. Check for coolant puddles around car when its parked. Check water pump. Do you see coolant pooling up anywhere in the bay? Do you smell it at all??
Old Apr 5, 2011 | 08:13 PM
ej1noob's Avatar
Ok this might help...
So I bought the car last week..
I saw the cap b4 I started it and yet there was white milky stuff..
I drove the car for like 45min stoped it 15min later came out from store.
Woudnt start gas was full... so I kinda though maybe water in the
System. B4 I start the car spark would not ignite cause of the water
In the motor... 45min after the car struggled to stay on and
Loads of white Smoke came out... been 4 days w that
Problem now 2 days ago I changed the oil put 20/50 and Lucas
To thicken the oil.. and its been good so far..
No oil leaks and NO COOLANT LEAKS..
tried takin spark plug out and 3 are stuck only one came out
Piston #3 checked compression 135 would really wanna
Check the rest but too afraid they won't go back in...
Sooo what chat think???? The car does not overheating
Even when I have the ac full blast stays normal..
Old Apr 5, 2011 | 08:23 PM
I'm sorry. You make my head numb. I give up.
Old Apr 5, 2011 | 08:29 PM
ej1noob's Avatar
Sorry 4 ur numbness!!!
Old Apr 6, 2011 | 02:54 AM
grumblemarc's Avatar
The Grumpiest
Problem
If that doesn't sound like a blown head gasket I don't know what does. Do a compression test.
Old Apr 6, 2011 | 05:40 PM
ej1noob's Avatar
See he understands...lol
I am as soon as my. Db1 gets out of the shop..
Old Apr 6, 2011 | 07:41 PM
ej1noob's Avatar
I cant till i get my db1 out the shop...
3 sparkplug are stuck and very hard to come off
scaleone
Aug 24, 2016 11:11 AM
ramonjones16
Sep 1, 2009 10:20 AM
jawsiiv
Aug 19, 2009 09:45 PM
som3on3_10
May 18, 2006 06:56 AM
drdavidge
Dec 29, 2002 04:25 PM
