LS VTEC SWAP PROBLEM!
I HAVE A 1998 EK, Hx
LS VTEC ob2a
The ignition is not getting power, no ignition spark, ignite. WTF!
The engine cranks, the gasoline flows, just the ignition is not powering. IDK
SPARKPLUGS ARE WET.
Also THESE CODES COME UP IN MY Comp.
P0113
P1259
P1509
I NEED HELP ASAAP
LS VTEC ob2a
SPARKPLUGS ARE WET.
P0113
P1259
P1509
I NEED HELP ASAAP
Fix the things causing the codes. Did you test for spark or you just guessing there is no spark?
I still need to check the fuses under dash, their is no spark i had a mechanic check for me, he is still checking, i work on my own cars but i rather have another mechanic look at it.
