Battery Relocation
Old Apr 5, 2011 | 07:35 AM
dem0nk1d's Avatar
Default Battery Relocation
So it's time to relocate my battery into the rear trunk area of my EJ Civic. Now always in the past I've just ran 4gauge wiring to the stock hot location in the engine bay. Someone said the cars using wire tucks and what not are using 8 gauge to the starter. So does this mean I can run 8 gauge in place of my old standby process of doing a 4 gauge run from back of the car to engine bay?
Old Apr 5, 2011 | 07:37 PM
mouab18c1's Avatar
Default Re: Battery Relocation
Bigger is better in your situation!
Old Apr 5, 2011 | 07:47 PM
CIVIC47's Avatar
Originally Posted by dem0nk1d
So it's time to relocate my battery into the rear trunk area of my EJ Civic. Now always in the past I've just ran 4gauge wiring to the stock hot location in the engine bay. Someone said the cars using wire tucks and what not are using 8 gauge to the starter. So does this mean I can run 8 gauge in place of my old stand process of doing a 4 gauge run from back of the car to engine bay?
Use at least the 4 guage for sure. Also, don't use bulk wire. Go to your closest welding shop and get welding grade wire. It's a fine strand wire. Electricity runs through it better and more consistantly. That's why welders use it. They can run it for long distances and don't lose any energy doing so.
Old Apr 5, 2011 | 08:11 PM
dem0nk1d's Avatar
i've always used soft strand 4/2gauge wire. something you get from the stereo shops... but i'll check the prices at the welding shops.
Old Apr 5, 2011 | 08:23 PM
CIVIC47's Avatar
It's the exact same wire as soft strand. It should be a lot cheaper at the welding shop. They buy and sell in bulk. Pass the savings to the consumer. At least that's the way it is in So. Cal. The outer casing won't be pretty though. It will be heavy duty, oil resistant, and thicker then what is sold at the stereo shop. I myself prefer function over form. The stuff is really tough.
Old Apr 5, 2011 | 09:10 PM
dem0nk1d's Avatar
I don't think it's gets anymore SO.CAL than San Diego.
Old Apr 6, 2011 | 06:05 AM
fcm's Avatar
fcm
Old Fart
Welding cable FTW, use at least 4ga or you will have "voltage drop" current will also suck.
Do not use a splitter box, run 4ga from batt., [install in-line fuse] to starter motor, then run an 8ga from starter motor to engine bay fuse box. 94
EM1 Resto
12
Oct 14, 2009 12:42 AM
G2ILS
Jan 17, 2005 12:14 PM
speedemon
Jan 13, 2005 09:43 PM
rice r0cket
11
Jul 5, 2004 03:43 PM
TAG
Jul 31, 2003 10:37 PM
