Ok, I am putting 2 mufflers on my turbo tegra, one on each side...words of wisdom?
Old Sep 27, 2002 | 06:52 PM
freeplay's Avatar
Default Ok, I am putting 2 mufflers on my turbo tegra, one on each side...words of wisdom?
I know it won't help that much, but I barely see dual mufflers on hondas/acuras. But anyway, I bought 2 apex'i turbo mufflers, and am going to have them put on this week. I was wondering if there is any good/bad ways to tee the pipe, or anything I should be careful of. Is it easy to make another hanger for the second muffler? Thanks
Old Sep 27, 2002 | 07:10 PM
Kamin's Avatar
Default Re: Ok, I am putting 2 mufflers on my turbo tegra, one on each side...words of wisdom? (BoostInBoi)
how about no.
dont be stupid, 4 cylinders, 1 header, 1 MUFFLER
if you run a 3inch exhaust its more than enough room to let the gases exit.
and thats only if your turbo. you bought turbo mufflers so i assume you are, if you arent one more from me.
the bigger the exhaust piping the more power it makes, but if its too big you will KILL your low end. its a give and take.
[Modified by KAMiN, 8:23 PM 9/27/2002]
Old Sep 27, 2002 | 07:38 PM
Batoutahell's Avatar
Hell, while you're at it, why not run piping for 3 or 4 mufflers? That'll really kill your exhaust gas velocity. If that's what you're trying to do.
Old Sep 27, 2002 | 08:18 PM
Blaze45's Avatar
Brrraaaap!
Default Re: Ok, I am putting 2 mufflers on my turbo tegra, one on each side...words of wisdom? (Batoutahell)
dont try and be like that shitty yellow civic @ our school. hes all show no go im sure of it.....
Old Sep 27, 2002 | 08:54 PM
TREVER's Avatar
2 mufflers will help make all of the power your going to need to spin those wheels boi.
Old Sep 27, 2002 | 11:52 PM
ciRcuitJerk's Avatar
jus f0 dekarayshunZ
Default Re: Ok, I am putting 2 mufflers on my turbo tegra, one on each side...words of wisdom? (TREVER)
1 muffler on a 4 banger .....unless your show
Old Sep 28, 2002 | 01:59 AM
EKFerioHawaii's Avatar
2 mooflers = a bad idea.
Sell one and spend the money on some Omori gauges!!
Can I get an amen on this one?
[Modified by EKFerioHawaii, 3:00 AM 9/28/2002]
Old Sep 28, 2002 | 03:59 AM
mugenracer's Avatar
Default Re: Ok, I am putting 2 mufflers on my turbo tegra, one on each side...words of wisdom? (EKFerioHawai
As above..dont do it, apart from losing low end power/torque, it looks crap..sorry!
Old Sep 28, 2002 | 07:14 AM
Archidictus's Avatar
Unceasing Measure
you do what you need to do to make up for your low self esteem. But, please, not at the expense of your car.
Old Sep 28, 2002 | 01:38 PM
Nameless RB26's Avatar
There is the reason you don't see it very often. Because it's useless on a 4 cyl, and it's rice.
Old Sep 28, 2002 | 01:41 PM
earl's Avatar
Bet you're sorry u asked...
Old Sep 28, 2002 | 01:44 PM
dmotoguy's Avatar
thats one of the funniest posts i've ever seen, why do something that will make you loose hp, look like ****, and cost more???
but then you and wilfong could have matching dual exausts
Old Sep 28, 2002 | 03:00 PM
forthgeneration's Avatar
if you really want to do it, then just rig one up normally and mount the other one. so one of them is a dummy exhaust.
i wouldn't waste my time making both of them functional.
Old Sep 28, 2002 | 04:06 PM
LS-Rt's Avatar
Default Re: Ok, I am putting 2 mufflers on my turbo tegra, one on each side...words of wisdom? (forthgenerat
I doubt you are going to lose any back pressure at all if you just tee off at the end. In fact, it might even become more restrictive if you use a crappy/tiny tee. GL
Old Sep 28, 2002 | 04:07 PM
miahmouse's Avatar
AMEN ..... even though I'm not a big fan of gauges......
Old Sep 28, 2002 | 04:37 PM
chad's Avatar
Moderator
RICE BOI....aaaaaaaaaaaaaaahhhh i need 2 of the bigones by tonight!!!
Old Sep 28, 2002 | 10:28 PM
dmotoguy's Avatar
do you know what backpressure is?? he would gain back pressure by teeing off... it would be more restrictive
Old Sep 29, 2002 | 07:34 AM
Anyone who thinks backpressure is a good thing does not understand how an engine and exhaust work together. A good exhaust balances two things: 1) minimal backpressure, 2) without sacrificing high gas velocity.
This has been discussed many times. https://honda-tech.com/zerothread?id=185545
Old Sep 29, 2002 | 10:33 AM
Al Bundy's Avatar
2 mufflers on a 4 cylinder is a bad idea, but can somebody explain why the s2k has dual mufflers? I've always wondered about that.
Old Sep 29, 2002 | 09:53 PM
wickedik's Avatar
turbos need SOME back pressure to run correctly.
Old Sep 29, 2002 | 10:49 PM
B18C-EJ1
Guest
Posts: n/a
Do you understand that most modern cars require back pressure for the EGR valve to work properly?
And, yes, BACKPRESSURE is still your friend. You even said it yourself....
A good exhaust provides "minimal backpressure"
As long as there is SOME type of header, cat, piping, and muffler, you'll always have some backpressure.
Old Sep 29, 2002 | 11:41 PM
miller's Avatar
2 mufflers + integra=
Old Sep 30, 2002 | 06:16 PM
LS-Rt's Avatar
hmm, you just repeated what I said. Thank you for playing, please try again.
acura95integra
Feb 16, 2008 03:59 PM
96lewd
Jun 6, 2004 10:30 AM
blackriceman
May 5, 2004 06:41 PM
B18B1DOHC
Sep 16, 2003 10:50 AM
Hyjnx
12
Jan 10, 2003 09:40 AM
